Guide Motherboard Painting
Discussion in 'Modding' started by hacker 8991, 8 Jun 2004.
  1. hacker 8991
    hacker 8991 What's a Dremel?
    8 Jan 2004
    Be brave! Paint you system!
    - tf
  2. japala
    japala What's a Dremel?
    8 Dec 2001
  3. hacker 8991
    8 Jan 2004
    Hmm, I had seen that before, or maybe after I posted the thread, but for some reason, it didn't register in my head. Sorry about that. I'll fix my first post.
    - tf
  4. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    i was wondering since i have a ECS p4vxasd2+, which is an ugly purple color, and doesnt match my radeon 9800 pro or ram. I really dont want to risk painting it, but could i just take a sharpie marker and color the whole thing black by had, or maybe silver?
  5. hacker 8991
    8 Jan 2004
    I think that using a Sharpie would be just as risky as painting it, and it might even take longer. Its up to your though, just post some pictures :D
    - tf
  6. psyphen
    psyphen What's a Dremel?
    20 Jul 2004
    A sharpie would most likely come off easier and not look as good as a paint job.
  7. timbudtwo
    timbudtwo What's a Dremel?
    14 Apr 2004
    Plus the fact that sharpies (and all markers that dry quickly) reabsorb (on certain materials) the colored pigment they put out because the carrier chemical picks it back up as you run over it again (you would never be able to do a line for line paintjob with a sharpie).
    That's why when you use a marker on a white board and you try to make a solid color, you get those nice white streaks!
    [Rant]
    I'm really enjoying this thread, but I like a lot less all the cranks that are giving hacker a hard time. I know its your irrevocable right for free speech, but posting just to say you don't like it is ridiculous. You are only racking up posts numbers. It's his motherboard, his warranty, and his money, let him do with it how he pleases. I may not agree that it looks good, but I'm not going around saying "You are going to ruin it!," "Are you Stupid?"
    I'm not trying to be bait and start a flame-war here. I'm just tired of seeing people attempt to do a Mod that isn't commonly done, and get ragged on for it. This guy seems like, for the most part, he knows what he is doing.
    [/Rant]
    I like the white color better than the black color personally. But it would be interesting to see some of that Mirage paint (color shifting paint). What would even be more incredibly cool would be to use that heat sensitive stuff that changes from black to red, or what-not, when heat is applied, then you could show off the hotspots in your case and be all suave!
  8. 1st time modder
    21 Dec 2003
    i painted my motherboard with the sharpie, and it works perfectly!. At first i was notice the white streaks, but then realized that the way to stop them would be to apply two coats, the first one drys then i apply touchup where ever needed. Here are some pics.
    heres where you can notice the largest difference in color,
    here it is almost completely finished just a touch-up here and a touch up there, touch up, touch up, everywhere! :hehe:
    Last but not least here is the motherboard in its fully completed state with all the components attached to it.
    I'm happy to say that painting it with a sharpie didnt increase the avg. temperature of the motherboard at all, but unfortuneatly it doesnt look as good as if it were painted properly. :sigh:
  9. timbudtwo
    14 Apr 2004
    Hence: On certain materials. Im surprised that it didnt get reabsorbed on the second coat when you did it on the metal parts, however. Still looks nice for a marker!
    Is than an athlon 64?
  10. 1st time modder
    21 Dec 2003
    nope its not an althon 64 (I wish). Its a Pentium 4 2.0A ghz. What a piece of crap. Only runs at 400FSB, and is a northwood core.(thats why i have such a large heatsink on it)
    EDIT: if you look closely in the 2nd picture, you should notice what kind of case i have :eek:
  11. FalconXp
    FalconXp What's a Dremel?
    14 Aug 2004
    But don't you think that the colour painting would be liquid with the high temperature of the motherboard?
  12. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Black absorbs heat?!?!?!
  13. timbudtwo
    14 Apr 2004
    [topic=off]
    Lol, Black sure does absorb heat, but it also gives it off quickly as well. Pentium 4 2.0 POS? Wtf? I had a p3 933 with a broken heatsink (basically it was resting on the core, not clamped on) that was underclocked. I upgraded to my current Athlon 64 beast... Aww i love her.... Ill name her Lauren.. err.. Yeah. Anyway, if you dont want that CPU, ill take it! You can go over to frys and get an athlon 2900+ and mobo for 110 :).[/topic]
    Falcon, it depends on what kind of paint you use. Most paints are only liquid because they are dissolved is something, so otherwise they would be a solid. Hacker also said that where it gets hot the paint just gets burned off.
  14. 1st time modder
    21 Dec 2003
    hey tim, since i dont currently have the funds to invest in a new CPU and motherboard (all of its going to make my HTPC), I still need to hang on to the CPU, the only thing I would replace would be the mobo.
  15. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    ok, i have a load of revell paint in small tins that i usually use for airfix and small details on cases, would this be conductive? as i intend to to use the white revell paint to highlight areas on the motherboard so they show up in the uv light
  16. dom_
    dom_ --->
    4 Jan 2004
    the only way to find out is to paint a large blob on something then use a multimeter to see if it conducts.
    Multimeters are only £5 for a cheap one, which is very cheap when you consider the price of a new mobo ;)
  17. FLECOM
    FLECOM What's a Dremel?
    3 Feb 2003
    Krylon makes a "Stained Glass" paint, its semi-transparent and bascially colors things... think this would work very well for a mobo becuase then you can still see all the traces and text that was silk screened onto the mobo...
    i wont be trying this on my Tyan 2462 tho :worried:
    check out this link:
    http://hardforum.com/showpost.php?p=1026118780&postcount=77
  18. viLe_aSiD
    viLe_aSiD What's a Dremel?
    4 Aug 2004
    how does the paint on the heat sinks effect the cooling????
  19. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    it will affect it a but in Temp wise i'm *geussing* about 1-3 degree difference, and if you are painting the mobo then i would asume that it is not your personal gaming rig, and then the temps would not matter that much
  20. NicePants42
    NicePants42 What's a Dremel?
    16 Jan 2004
    Black absorbs most wavelengths of LIGHT, and thus heats up. A black motherboard in a hot, dark room will not absorb any more heat than a white mobo in a hot, dark room - until you shine a 100W light buld on it. Hell, even then the temp difference would be small. There are quite a few components that use black PCB (mobos, vid cards, etc).
