Hello, I was looking at getting the Gigabyte GA-X58A-UD3R Motherboard and I was wondering if it had hyper threading support or not. I was also looking at the EVGA X58 SLI LE Motherboard as another option. which one would you recommend for overclocking and gaming? I plan on using the Core I7 930 processor. thanks in advanced
It's more a case of whether the board supports a CPU that has hyperthreading - and yes this board does support the core i7 930.
They are both great boards, but I'd go with the gigabyte, according to custom pc mag its a great board!
