Specs: ECS H81H3-TI2 8gb Kingston Sodimm ram 30gb Kingston m.sata SSD I5-4590 I was using for a mini media oc, but it would seem that the motherboard has died overnight? Was working perfectly fine yesterday, but now there is no output on the HDMI (only display output on the rear IO) and after a few seconds everything powers down and seems to re-boot.. I've tried looking at the board, but nothing seems off (blown parts, dry solder etc).. Removed all hard drives and anything Sata powered (as the whole board is powered by a 19v laptop brick) in case it was running out of power.. Also tried swapping the cpu, still same issue. Can anyone think what might be wrong with this setup? Normal ITX boards for 1150 are getting mighty expensive, and can't afford a full upgrade for what's supposed to be a cheap and simple htpc!
