Hello! My current watercooled computer is beginning to show its age. As I begin to put together a new system, I was wondering what micro-ATX motherboards other folks found really nice for water cooling? Ideally I'd like to cool the cpu, the northbridge and the graphics card, although I wouldn't be closed to the idea of cooling additional components. Unlike some folks, I'm not doing water cooling to overclock my system, I'm just doing it for the stability of a consistantlly cool running system. And I'm only looking at micro-ATX motherboards (or smaller) because anything larger won't fit into the old NeXT cube case I'm working with. Thanks! AT
What processor are you thinking of using? if an AMD, try any of the nforce or ati ones, they both have good component placement, although I have the Sapphire ATI Radeon Xpress 200P matx board, as the northbridge is no longer under the pci-e slot as it is in full atx boards if an Intel, the Asus P5LD2-VM looks ok, as it has roughly same positioning of components, allowing easy access as well. both these are readily available, try ebuyer as thats where I looked, and are quite good. c.u.later
Neat. The Sapphire ATI Radeon Xpress 200P matx board looks really nice. Can anyone suggest a US source for the board? Thanks!
