Does anyone know how to disable CPU fan shutdown on a DFI LANPARTY UT nF4 Ultra-D, you can't get the temps to go down any lower than 25c because the fan turns off at this point so my fan just turns on and off anyone know what to do to fix this?
Bios settings. Can't remeber exactly where they are, but there should be an option to turn off the speed sense... Why do u want temps lower than 25 deg anywho?
thx for the input, I used another fan header but any fan hooked to the mobo is like this, and I want temps lower than 25c for overclocking
You'll need to disable the temperature controls on the fans then Theres a bios option able to do that. Afaik smart guardian will also give you the option to run the fans at full speed too....
