Motherboard Temps
Discussion in 'Hardware' started by Carlk, 27 Jul 2004.
  1. Carlk
    Carlk What's a Dremel?
    10 May 2004
    just been thinking, what part of the whole motherboard is monitored? it cant be the board its self can it?
    or can it :confused:
    thanks
  2. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    There's usually one sensor beneath the CPU in the middle of the socket and one somewhere else on the board that monitors the 'system' temp at that one point.
    Is that what you mean?
  3. Carlk
    10 May 2004
    yeap, so whats the best way to cool you motherboard? i have on fan blowing on to the motherboard. what else will help?
  4. jetsetjimbo
    19 Feb 2003
    Are you overclocking? The motherboard itself dosen't really need cooling, rather the components on it that generate heat.
    The most important thing really is to get cool air from outside the case flowing through the case. I.e drawn in by a fan on the front for the case and blown out of an exhaust fan at the rear or by the PSU fan.
  5. Carlk
    10 May 2004
    yeap i got my 2500+ @ 2300mhz, mobo at 35* and CPU at 38*
    just need 2 get the mobo cooler, what components should i cool?
