Build Advice Motherboard Tray
Discussion in 'Hardware' started by charless1, 7 Jul 2010.
  1. charless1
    charless1 What's a Dremel?
    7 Jul 2010
    First Let me introduce myself
    My name is Chris I live in Phoenix AZ and I have built several of my own systems but they have all been your typical Beige Box Builds.
    I finally have the time and space (Kinda) to do a Complete scratch built system. I have a few Ideas in my head :wallbash: I just need to figure out what I am going to use to build the Floor Board/MoboTray out of (Yes this will be a vehicle based Design) I know a Standard Tray "might work but what do you use for a Custom Tray what is the Preferred Material
  2. varkanoid
    varkanoid Professional Dribbler
    18 May 2010
    lego would be original.
  3. shoxicwaste
    shoxicwaste Minimodder
    2 Jul 2010
    indeed!
  4. Jipa
    5 Feb 2004
    The same material as the rest of the case? Or save yourself some time and effort and buy a factory made tray..
  5. charless1
    7 Jul 2010
    So a Brass Plate will work? The Entire Chassis and Roll cage will be made of Brass Tubing and the Frame is going to be made of Brass Square tube
  6. Jipa
    5 Feb 2004
    The material of the tray makes absolutely no difference at all. Brass is fine.
