Motherboard Trouble
Discussion in 'Hardware' started by 220689JC, 15 Jun 2005.
  1. 220689JC
    220689JC What's a Dremel?
    25 May 2005
    :waah: HELP ME :waah:
    need a GOOD motherboard that supports DDR2 PCI-E and intel socket 478 Prescott 3.2Ghz 800FSB can't find one. tried abit, asus and DFI and MSI have run out of ideas :confused:
    help
  2. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    What're the problems that you've experienced with the motherboards you've listed? They're all very good boards, have you just had bad luck with reliability or is there something you feel is missing from them?
  3. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    ok can i jsut ask does anyone even make any motherboards for the SKT478 that are PCI-E and DDR2? i thought they were only for LGA775?
  4. Kameleon
    29 Apr 2003
    Good point, I missed that :eek: AFAIK there isn't a chipset that supports 478 with the new technology, Intel abandoned their older processors when they moved on...
  5. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Intels 915 chipset supports PCI-e and DDRII :)
  6. Kameleon
    29 Apr 2003
    And only LGA775 not 478, no?
  7. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    You're out of luck man; socket 478 just plain does not support DDR2. There isnt a single motherboard in existence that fits the bill. You're either going to have to shell out for a new CPU, or get new RAM.
  8. Highland3r
    25 Jul 2003
  9. Austin
    Austin Minimodder
    16 Jul 2004
    :confused: It will be difficult but shouldn't be impossible. For instance there's a few wierd mobos which have both Skt478 & LGA775 which may fit the bill. Skt478 is predominantly DDR(1) & AGP though, and that's not actually bad at all esp with DDR(1) still being a lot cheaper than DDR2. TBH I'd suggest you sell your sweaty Prescott as it's notoriously hot and has compatibility issues on Skt478. I'd suggest selling it and buying a LGA775 P4 or else but a Skt478 NorthWood CPU (always 512K) which is slightly faster per clock cycle and runs much cooler too.
  10. 220689JC
    25 May 2005
    Oh Well!!!
    DAM :wallbash: it looks like i am going to have to use skt LG775. thanks for ure help.
    i just need someone to desgin a motherboard that is compatable :D ha!!!
    :grr: DIE INTEL DIE:grr:
  11. riluve
    riluve What's a Dremel?
    29 Jun 2004
    You do realize that without Intel we would all be using Motorola 6800's and an ISA bus right? besides the obvious CPU development, they designed PCI, AGP, USB, etc etc etc. Just thought I'd mention that before you get out your hachit.
  12. 220689JC
    25 May 2005
    oooo sorry (Sarcasm)
    if u are so in love with Intel go and marry them
    i know what they have done i just hate them now, cos i can't find a motherboard :waah:
    so
    DIE INTEL DIE
