I was looking for a way to go from a normal USB 2.0 cable end to the MoBo USB port Headers. Does anyone know of an adapter or a way to cut the cable and ends to connect. Any help will do!
If you can handle soldering just buy a 2.5mm pitch 2x5 (I'm pretty sure they're 2x5) plug - and solder the individual wires from the USB cable to it.
It's 2x5 for 2 ports you only need a 1x5 for a single port. You will find the headers either as .1" or 2.54mm both the same, just dufferent units.
