Other Moto g4 SD card problems
Discussion in 'Hardware' started by CrapBag, 17 Jun 2017.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I have a Moto g4 and think it's a great phone but I'm struggling to get a 32gb SD card to work properly.
    I have tried using the SD card on its own and also by formatting it so it's seen as one large drive.
    The card is seen for a while and works well but then disappears.
    This is the 2nd card î have had and both do the same (different brands). Both cards are fine in windows.
    I've researched the g4 and 32gb cards by are supposed to work, my 16gb worked fine.
    Any ideas?
  2. Big Elf
    23 Apr 2009
    Might be a faulty MicroSD card slot. My G4 (currently on Nougat) has used a Samsung and Sandisk 128GB card (formatted as exFAT) without problems. Both have been used a a separate drive only.
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Its working again at the moment after I forgot to charge it and thus it turned itself off. Looks like a reboot fixes it which could point towards a temperamental slot.
