Motors Motorcycle Mayhem
Discussion in 'General' started by RTT, 24 Feb 2009.
  1. RTT
    RTT #parp
    12 Mar 2001
    New front tyre time for me, it's knackered! Expected it to last longer, it's worn in the exact reverse of a (typical) rear tyre - the sides are shot, and the middle of the tyre is fine! Must be a massively soft side compound (or overly hard middle compound). 6.5k miles, was hoping for 8-10 :( Pirelli Diablo Corsa III...
  2. Xir
    Xir Modder
    26 Apr 2006
    I don't think the corsaIII's front tyre is dual compound.
    Anyway it points towards your driving style :D Braking into corners?
  3. RTT
    RTT #parp
    12 Mar 2001
    I think you are right! I can't ever remember seeing the visible changes in compound like you can on the rear!
  4. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    I can't see the difference between compounds on my tyres and I can only feel it when the tyres are warm.
    Moriquendi
  5. Xir
    Xir Modder
    26 Apr 2006
    Of course Pirelli doesn't tell you anything on their website :duh:
  6. Moriquendi
    3 Nov 2005
    Switch to the PR2s, they're ace. I imagine you'd get better life out of them than me because your bike is considerably lighter (140kg to my 230kg)
    Moriquendi
  7. Xir
    Xir Modder
    26 Apr 2006
    140kg? What the...Cagiva Mito?
  8. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Just cycled with my dad to and from my nans house and his comment was 'remind me never to ride motorcycles with you', asking why he replies 'cause there would be some competition!'
    i.e. on pushbikes we ride a bit too aggressively, hell can't lose a pushbike license and they're a little bit skinnier than a motorbike!
  9. Moriquendi
    3 Nov 2005
    RTTs KTM, I was quite shocked at the difference to be honest.
    Moriquendi
  10. aradreth
    aradreth What's a Dremel?
    20 Aug 2009
    The ktm I have seen RTT post is a 950sm (do want by the way that or a SD... :naughty:) which will weight ~200kg with fuel.
  11. Moriquendi
    3 Nov 2005
    Oh right, I thought he had a 690.
    Moriquendi
  12. RTT
    RTT #parp
    12 Mar 2001
    690? Pah! :D 690s are for girls!
    I am going to look at a Superduke R this weekend ;)
  13. aradreth
    20 Aug 2009
    Lucky *******! Report back how it handles because I've now got a bit of money to spare (but no time :sigh:) so I want take a SD out for a spin at some point :D
  14. Moriquendi
    3 Nov 2005
    Weren't you originally looking at a 690? I get confused, they all look the same to me :p
    Moriquendi
  15. RTT
    RTT #parp
    12 Mar 2001
    I was originally looking at 690s, but then sense prevailed over and the obvious choice was, for the same cash, a 950, which is 10x better in every way :D
  16. Xir
    Xir Modder
    26 Apr 2006
    Grrr :grr: I drove a nail into my rear tyre...gotta replace it.
  17. Xir
    Xir Modder
    26 Apr 2006
    Do I need to tape off my headlight when I drive my bike to the UK?
  18. Krikkit
    21 Jan 2003
    Do bikes have specific LHD/RHD lights?
  19. Moriquendi
    3 Nov 2005
    Bikes do have handed lights, they dip away from oncoming traffic so you prbably should tape them.
    Moriquendi
  20. Nikols
    Nikols What's a Dremel?
    13 Oct 2009
    the new pirelli angels look class and are getting good reviews, my mate picked a set up two weeks ago and reckons they're excellent, especially in corners (he switched from corsa iii's) Corsa iii's have bin around a hell of a long time and the tech is old. I've bridgestone battlax BT021s on the bandit 12 and have the same problem as you with front, I travel an empty backroad with 7 or 8 lovely roundabouts to work every morning and I believe the excessive wear comes from riding spiritedly, rolling on the throttle while the bike is pitched over, the tyres really dig in when you do this. Anyways they've bin superceeded by BT023 now but don't think i'd trust them not to do the same and they're expensive. I've pirrelli supercorsa bsb's on the duke which are amazing but I wouldn't be pushin them on the wet and they don't last too long
    http://www.telegraph.co.uk/motoring/motorbikes/5257743/Tyre-test-Pirelli-Angel-ST.html
    the roads over there must be class, I wouldn't be complaining if I got 6.5k out of a set of tyres or a front tyre :-(. I get about 5k outa the bandit and max 3k outa the duke. All I do is buy bloody tyres....
