Motorola ads use much CPU
Discussion in 'Feedback & Suggestions' started by Smilodon, 18 Sep 2009.
  1. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I just noticed that Firefox ran a bit sluggishly. Turns out that the three Motorola Blur ads make my CPU (Q6600) run at about 50% constantly.
    It is a bit annoying. Especially if I'm sitting on a laptop.
    Could someone please do something about that? :)
    Don't want to turn adblock on for this...
    TIA
  2. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    About 60% CPU on an E6600 here.
    Had to take Bit off the Adblock whitelist to get this page to load with other tabs open. :sigh:
  3. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    40% usage here but 4% when the said advert is not being displayed. Deffo an issue.
    I'm sure one of the admins will sort that very soon.
  4. specofdust
    specofdust Banned
    26 Feb 2005
    35% of my 12Ghz. So the adverts on this current page are using 4.2Ghz of my CPU power. They're getting blocked. There's advertising, and there's raising my energy bills. This is the latter more than the former.
  5. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    Destroying my CPU Cycles here too!
    It's been great since the O2 advert snafu, and now its shite again.
    I thought publishers had agreed to test these adverts before they are put on view?
    i've been a solid supporter clicking adverts for Bit-tech, and bought many of my goodies from some of these adverts, but this takes the cheese :)
    please fix them bit's!
  6. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Lols.
    Issue here too. To the extent that I can't open a second bit-tech tab :(
  7. alastor
    alastor Minimodder
    6 Sep 2004
    Had to block these on my laptop to get any bit-ness at all, sorry guys.
  8. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    Same story with my Q6600, I thought it was the iGizmo ad at first though. This is the first time I've had to block bit on Adblock, but once this is fixed you'll be back on the whitelist.
  9. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    I've been running flash block since the o2 incident, my little epia can't cope with flash ads.
  10. Cheapskate
    13 May 2007
    6 minute page load for X3 Motorola ads here.:hehe: If you could just get the b*stard to ONE per page, all would be well.
    It's like advert slots...
    -1 ad: OK
    -2 ads: sluggish
    -3: Ctrl;alt;del time.
  11. roblikesbeer
    roblikesbeer Bindi's sex slave.
    23 Apr 2009
    It kills my laptop too (2Ghz dual core with 2Gb RAM) and as it's a work one I can't install adblock.
    As I'm typing this it's the only webpage I have open and my CPU usage is 50-60%!!!
    :nono:
  12. Combinho
    Combinho Ten kinds of awesome
    5 Aug 2008
    That was killing me as I'm running a P4 while the ebuyer shennanigans get sorted out. Thanks for pointing out what was causing it.
  13. Silver51
    24 Jul 2006
    Just one advert takes an E4500 up to 30-45%.
    How is this even possible?
  14. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    Shitty coded ad.
  15. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    The right people have been notified apparently and the issue should be fixed soon. In the meantime, everyone blame Hiren.
  16. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    100% on my laptop :(. Things... are... ... so... ... ... ...slow!
  17. Hiren
    Hiren mind control Moderator
    15 May 2002
    Yeah really not appreciated :miffed: especially since I have little to do with the advertising on bit-tech.
  18. SpeedLegion
    SpeedLegion Minimodder
    23 Jul 2009
    100% usage on my laptop :(
    Never used one before but gona have to go download an Ad blocker as its the only way I can still use bit from my lappy :( (will uninstall once advert gone :) )
  19. specofdust
    specofdust Banned
    26 Feb 2005
    Gotta say, even not including this, bit-tech fairly commonly has ads up that make it unusuable on my Eee.
  20. pennyman86
    pennyman86 What's a Dremel?
    18 Jul 2009
    Ya i was just about to make a post about the motarola add, when im at work it wont even load the page if theres a mota add sometimes i will get like 3 per page.
    Also Vertex add lags the heck out of my browser aswell
