News MountainMods U2-UFO Aluminum Cube Chassis at TwistedMods
Discussion in 'Article Discussion' started by GreatOldOne, 30 Jul 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    TwistedMods gets all excited over what can only be described as a large aluminium borg cube:
    "The U2-UFO is manufactured locally in my home state of Oregon, it's unique, nearly flawless in design, and is fabricated with great quality and attention to detail. Throughout my testing experience with this case, I could not get over the size! It sure is bigger than it seems in the pictures, but it is without a doubt a case that will turn heads at special events like LAN parties and seminars. If you are an overclocker or someone who likes to take cooling to the extreme, the 2mm aluminum construction will assist, and the fact that it houses SEVEN 120mm fans and an additional FOUR 80mm fans will allow you to keep your Dremel in it's case and out of the aluminum. While I am not a fan of pre-modified chassis designs, I don't have any problem sporting this case; its unique and large design will have people looking no matter what!"
    The full review may be assimilated here
    Fill that case with all the fans it can take and it'll be a danger to children and small animals - That or they'll be so much negative pressure inside that it'll implode! :D
  2. Spaced_invader
    Spaced_invader What's a Dremel?
    25 Sep 2002
    for the past month i've been thinking of building my own aluminium cube, the only thing i don't like about that case is the lack of a door to hide the bays
Tags: Add Tags
