Cooling Mounting a BIX/BIP 3 in a Lian-Li 6077
Discussion in 'Hardware' started by Guest-23315, 25 Feb 2007.
  1. Guest-23315
    Guest-23315 Guest
    I'm after a Lian Li PC-6077b and hoping to water-cool it, but there are two issues that i have.
    1). Where can i even find one of these cases?
    2). is there enough space along the bottom for a rad (not fussed about lossing a load of PCI slots, as i only realy need 2 or 3) without cuttng out part of the drive bays? (seeing as the rad is 120mm wide, and 15cm or so wide, a little like http://forums.bit-tech.net/showthread.php?t=98605&page=4.
    AJ.
  2. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    I looked everywhere for one of these cases my self, I finally found a store (eclipse computers) but their silly stock system is all wrong and they didn't actually have any and I doubt they ever will - PC6077/b's are now discontinued. So the only way I think you'd get one is by finding one second hand on eBay or Forums...
    Also looking a Scampi's mod the only thing obstructing the bays is the AC grill, or he might have rad quite far away from his mob, either I doubt it's too much trouble, I got a BIP 360 in my CM stacker fine :)
  3. Axel
    Axel What's a Dremel?
    20 Feb 2007
    The only 6077 case i can find is on xoxide.com and only in silver.Too bad if you live outside of the US.
    If i couldnt find 6077 i'd go for
    V1100B or
    V600B
    check them out
  4. Fr4nk
    12 Mar 2005
