Cooling Mounting holes on A7V266-E
Discussion in 'Hardware' started by [DE]FreD_S, 5 Apr 2002.
  1. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    Hi y'all !
    Got a new waterblock comin up ! I've even finally made pics, just need to bring the photofilm to to the shop ... anywayz this new sucka weighs in at 1 Kg ! Anyone know how much weight the mounting holes can carry, without me having to connect to the case as a further support ?
    Cheers
    [DE]FreD_S
  2. TiTch
    TiTch h2o cooled
    19 Oct 2001
    The heaviest that I know of is the swiftech at 789 grammes. 1kg is not much more, but what is this block that is so heavy????
  3. [DE]FreD_S
    6 Jan 2002
    It's a modified MC462 with an alluminium housing and 1/2" connectors ... a real "big mamma" hehe ...
    Cheers
    [DE]FreD_S
  4. Haddy
    Haddy World Domination
    22 Jan 2002
    hehe u should be fine...just make sure u attach it good and tight...i would use a shim (let the shim haters come rape me i dont care) just cuase its so heavy
  5. Lord_Vheox
    Lord_Vheox What's a Dremel?
    6 Feb 2002
    shim haters? You don't see them, they're useful, why hate 'em?
  6. Haddy
    22 Jan 2002
    good lord dont start this again....just trust me their around....type in shim in the search and ull find them...in all their stupidity
  7. TiTch
    TiTch h2o cooled
    19 Oct 2001
    Hating shims is not irrational Haddy. You might not realise it, but most of the problems in the UK over the last 30years have been caused by those insiduous little pieces of copper :cries: :cries:
  8. Haddy
    22 Jan 2002
    well if u put a peice of copper (which is conductive) on a bunch of condutors yea ur gona short out ur ****....but if u use a non conductive shim then ur all right
  9. TiTch
    TiTch h2o cooled
    19 Oct 2001
    Haddy, read my post again, a sensible answer was hardly in order.
    Seriously though I had the first ones that you could get in the UK which are copper and if you stick it on glass is bent to ****. It definately is worth getting a desent non conductive one for a few extra bucks.
