Windows Mouse Clicks being redirected to ads?!
Discussion in 'Tech Support' started by pete*, 25 May 2017.
  1. pete*
    pete* Something witty here.
    29 Apr 2009
    Morning all!
    Hopefully someone could help with this weird problem i'm having.
    Somehow I believe I have managed to get some malware.
    The problem is, I can't work out what it is that is doing it.
    I have scanned with kaspersky, defender, AMBytes, AdwCleaner, zemana,
    gone through a whole forum post to do with removing adware/malware using various programs like rkill, FRST64, sophos.
    NONE have found anything to get rid of on my machine. Tried in safemode and standard.
    The problem I am having is simply, clicking links, or infact anywhere on a webpage, randomly i'll have a page open advertising something.
    Sometimes a new tab, sometimes in the current tab.
    I also get one saying Firefox Safesearch incognito protect your privacy.
    It appears completely random, not every click.
    Windows 10, all updates current.
    Using firefox 53.0.3 (32-bit). I have reinstalled firefox twice, and disabled addons.
    Anyone seen this? Pain in the arse!
    Cheers for any help
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Have you checked the Startup tab in Task Manager for anything random looking? In fact, have you just checked the running processes in Task Manager?
  3. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Right click your chrome/ie/firefox whatever you're using and check it's launch parameters, in my experience it's either a toolbar that's missed, extensions or launch parameters.
  4. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Have you checked your "programs"?
    go into there and sort by install date, make sure it's not an app that has been installed and is doing it.
  5. pete*
    29 Apr 2009
    Yeah checked the services/programs/startup tabs in TM. Nothing strange there.
    No strange parameters in short cut, or in urls in the actual settings of firefox.
    No apps installed that I didn't do myself that are showing.
    Just can't work it out, very very strange. :(
  6. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
