Peripherals Mouse mats....
Discussion in 'Hardware' started by longweight, 24 Aug 2011.
  1. longweight
    7 May 2011
    Hi all,
    my Logitech MX Revolution is starting to get a bit stuttery, I think this is due to the desk surface having quite a few small holes in it :D and the crap it picks up off my desk as I wire light fittings most days.
    Does any one still use a mouse mat? If so what do you use? Not really sure what to go for!
  2. Parge
    16 Jul 2010
    I use a Razer Sphex! Very very thing, not much good if you move your setup around lot as it sticks to the desk, but its very thin and a very good surface for FPS. (oh and its cheap as chips)
    My Amazon Review
    "My situation is that I don't have a huge amount of deskspace but play a lot of games so wanted a mouse mat for them. Lets first get out of the way what kind of difference a mouse mat makes. Wow, I had no idea. My mouse drifts across the surface like its hovering on a cushion of air. I use a Sidewinder X5, and the difference is not just perceptible but striking. I can't tell you anything about my K/D ratio improving or anything like that but it definitely makes a difference.
    So, onto the mouse mat in hand, the Razer Sphex. Well the first thing you'll notice about it is how thin it is, barely thicker than a sheet or two of good quality paper. I cleaned my desk surface (fake wood), before putting it down, and its stuck there ever since with no movement. I'm not sure how it clings on, and it might not be good for those of you who regularly move your mouse mat around. Because of how thin it is, my keyboard can sit on top of it without any wobbling or tilting. It also looks pretty cool, if aesthetics are important to you. The surface itself appears to be a rough plastic, and as previously mentioned, makes using a mouse a joy.
    To sum up, I'd say the Sphex is good for anyone who wants to improve their gaming, needs a thin mouse mat, doesn't want to spend the earth, and doesn't move around too much. "
    BlancAnarchy likes this.
  3. Crackdown_uk
    Crackdown_uk What's a Dremel?
    19 Aug 2011
    I'm not sure if they're still one sale (mine was a freebie anyway), but a Razer Exactmat is pretty good from my personal experience;
    It is double-sided too, one surface is designed for grip (I prefer more resistance) and the other is for speed. Worth checking out, it's the only mat I've used in years aside from a piece of cardboard - I was even playing competitive FPS at a high level using it :lol: - and a el-cheapo cloth job from a pound shop.
    Guess it's all a matter of preference.
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Steelseries QcK+ here, typically good mouse mat. :)
  5. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    +1 for the Razer Sphex here. So nice to use. I won't repeat what Parge said, but it's all spot on.
  6. dave_salmon
    dave_salmon What's a Dremel?
    24 Jun 2009
    Despite the name sounding like is was specifically chosen to appeal to 13 year olds, I use a nice big Cyber Snipa (I really do hate the name). It's pretty huge but really comfortable and works like a dream with my G5.
    Its gone up by nearly £5 for some odd reason but it's worth a look if you can find it for £10.
  7. Bede
    Bede Minimodder
    30 Sep 2007
    Thing about mousemats is that almost any surface that isn't a desk or one of those 1990s foam-based mats will be a huge improvement, paying over £15 would be mad. Sphex sounds interesting, thanks.
  8. rv88uk
    rv88uk What's a Dremel?
    28 May 2011
    I've got a steelseries I-2 which I have to admit is a little expensive for a mousemat, but my last rubber mat (a QPad mousemat) decided to start melting onto the desk, it wasn't fun, so I went something more durable.
    Anyway the I-2 looks great (black frosted glass) and performs well (it's very accurate) but it is quite loud, there's a scraping/swishing sound as you move the mouse. You get used to it (I don't notice it anymore) but some would find it annoying. It also gets quite cold, which is nice in summer, but in winter it could be a bit unpleasant. I do think it was worth the money though (I wanted aesthetics as much as performance).
  9. Teelzebub
    27 Nov 2009
    Steelseries extra large size 18" x 16" for me works great
  10. longweight
    7 May 2011
    Thanks for the feedback guys, will have a look through them :D I used to have a cloth mouse mat but I just stopped using it for some reason.
  11. Kronos
    Kronos Multimodder
    6 Nov 2009
  12. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I have a razer destructor and a steel series and both have never given me any hassles
    Sent from my GT-I9000 using Tapatalk
  13. Lance
    Lance Ender of discussions.
    6 May 2010
  14. jrs77
    jrs77 Modder
    17 Feb 2006
    Steelseries 4HD in use here. Very thin, comfortable texture with very little drag and very durable.
  15. Sexton
    Sexton Minimodder
    2 Jun 2010
    Using a Razer Goliathus here - brilliant thing, and available in several sizes :)
  16. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
    i was just reading on mouse mats the other day, bought the above and its amazing!! (compared to a normal standard thing)
    got it off amazon.co.uk, was the standard speed edition
  17. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    5mm stainless steel plate 250 x 410 with rubber base will take pic later :thumb:
  18. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    I'd also recommend the SteelSeries QcK mats, they're very cheap, durable and have great glide.
  19. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I use the Exactmat with the Exact Wrist rest, but I think it's doscontinued, but this looks simular. i love the wrist rest as I used to get really bad RSI in my right wrist, but its helped massively :)
  20. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
