Electronics Mouse Mod - Fading LED (finished, giffy of mouse uploaded:)
Discussion in 'Modding' started by Pygo, 9 Jul 2003.
  1. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    YAY... my first thred... LOL:clap:
    sorry...
    I just bought a Logitech Wheel Mouse Optical (using USB port)and plugged it in.. played c-strike for less than a minute.. and decied I liked my new mouse and that I would keep it. I then took it apart:naughty:
    Everything fell out when I ripped out the pcb(well, ok... I was gentle with it...) but I got it all back together alright
    Well, now for the mod... I want to add a capacitor between the leads of the LED to make a fade effect of about 1 to 4 seconds when the mouse goes into a power saving state (I think that's what it does). Anyways, the led goes dark rather quickly after no movement, and thought that a fade effect would be cool.
    The voltage I can find myself, with me multimeter.
    Shall post voltage once I take the mouse apart again, in case any one is interested...
    well.. the voltage when the LED is on full power is 2.17 Volts
    and when in standbye like mode it is 0.19 Volts
    And am currently using with the cover off... :clap:
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Sounds awsome can't wait to see some pics (if you got them)
  3. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    lol.. I think I gonna need a bigger capacitor than what I got...
    I just tried a 1000uF electrolitic rated at 25V and no go.. even on a normal green LED, the fade was a bit longer than wanted...
    So I may require some circuitry to fade it between the two...
    sniff.. so much for a simple mod that takes less that 30 seconds to do...:waah:
    know of any ways to fade do that?
    Don't worry.. all is not lost.. if I have to, I will make my own circuit to do that :)
  4. ZapWizard
    19 Sep 2002
    You can choose a smaller cap, or you can use a transistor (And put the cap on the base of the transistor)
  5. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    Thanks
    Shall try that now with the green led...
    post again in maybe an hour or so, or sooner if I get it working/burn something out... LOL
    ok.. I got a test to work...
    I forgot that the led would have a current limiting resistor between it and vdd... LOL
    so...
    my test circuit looks like:
    Code:
              vdd
    cap     resistor
     |        LED
              Gnd
    and the fade works great with the 1000uF cap...
    BUT... I must find out the current draw of the led.. so I shall hack apart the mouse a bit... LOL
    and then maybe get the circuit into place after I find out the current draw and find out which led lead has the voltage change on it and use that as either ground or vdd, and change the circuit accordingly...
    Thanks for your help ZAP... made me get out my bread board...
    ok.. well... I did have to use a transistor.. and almost burnt one out... hooked it up wrong and wondered why it never worked. So I tried checking to see if it was hot and burned my finger.. :wallbash:
    but I tested it with the mouse and works fine...
    shall post a schematic and piccies of what I did later tomorrow sometime... and hopefully a vid of the fade effect :D
    Now all I gotta do is cut the wires to the led...
    Well... got it all wired up and a pcb all soldered up. Then I put it in me mouse...
    Looks great...
    But theirs only one thing...One of my friends that has the same mouse hates me now(well, hes actually jealous but whatever):hehe:
    I shall add piccies and maybe an animated gif. And maybe I shall do up the schematic on my computer since my writing is really messy.:D
  6. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    I merged all your posts. 3 posts in a row is generally not a good idea. Use the "Edit" button not the "Post Reply" button if your post was the last one :D - :: Phat ::
  7. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    Thanks for advice Phat... never thought of that:duh:
    ok.. I got a schemtaic all done up.. and hope to get some piccies of the circuit in action.
    I also changed the red led for a green one:naughty:
    the schematic done in eagle
    yes yes.. R1 is about half what it should be... but I wanted the green led to be a bit brighter, and is not at the maximum rating of the led.
    The vdd wire connects to the red wire coming in from the mouse which is about plus 5 volts. Ground is either of the two black wires.
    Any comments would be nice, thanks :)
    EDIT: ok.. here is a crummy animated gif of the mouse... and my fingers:naughty:
    note: effect looks WAY cooler in real life, and led is looks brighter... In fact, how bright it looks when is on full power in pick is about what it looks like when in power saving mode.
    Anyone want pics of the connections on the pcb???
    Don't worry, I soldered most of everything... :p , except vdd and gnd
    Questions, comments.
  8. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    what LED are you fading? the tail light or the sense light?
    I'd love pictures! very cool.
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    That means the transistor is connected the wrong way round as shown.
    And as ZapWizard said, small caps can be used between transistor base and ground instead of big ones across the led.
