Modding Mouse painting
Discussion in 'Modding' started by Dezjay, 25 Jan 2006.
  1. Dezjay
    Dezjay What's a Dremel?
    10 May 2004
    Hi,
    I need a black glossy mouse. So i have to paint a logitech one... But the MX/G5 mouses all have a glossy coat on it.
    How do i start? do need to sand? and prime ?? or ??
    It must behard because the mouse will be used a lot.. any idea?
  2. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    sand - paint - light sand - paint - paint - paint
  3. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    paint LIGHTLY.
    LIGHT COATS ARE KEY.
  4. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    wetsand with 600 grit -paint lightly-paint lightly-wetsand with 700-2000 grit-paint 1 last light coat- then paint 2 coats of clearcoat again lightly- then wetsand with 1500-2000 grit - then buff with rubbing compound-
  5. doryakov
    doryakov What's a Dremel?
    8 Aug 2005
    you have many mouse painting guides . google it or search it in the forum , you will find something that help you.
