Windows Movie won't Play!!!
Discussion in 'Software' started by DoNuT, 12 Apr 2005.
  1. DoNuT
    DoNuT What's a Dremel?
    20 Dec 2004
    I have a movie that is in .avi format and says it should work with divx, but I downloaded all the divx players and when i tried to open it in divx it gave me an error like it:
    The video file you are opening includes video data that is not recognized
    by the DivX Player.
    The file contains the following type of data:
    video data: FOURCC code "xvid"
    You may need to install a new video codec on your computer to watch
    So I installed the Matroska_Pack_Full_v1.0.3 codecs and it seems to open, but it doesn't play when I click the play button. Please Help.
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    The error you got says that the movie file is an xvid, so you need the Xvid codec from here.
  3. DoNuT
    20 Dec 2004
    ok...i downloaded that file "xvidcore-1.1.0-beta2" and tried to play the movie and it still won't play. I extracted it and put it in the Xvid folder and still doesn't. Where do i extract it to or what do i do with it. Note there was no executable that came with the file.
  4. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    My bad. I sent you to the page for the codec source code. :duh:
    I should have given you this link.
  6. Guest-16
    Guest-16 Guest
    remove everything and just use ffdshow.
  7. DoNuT
    20 Dec 2004
    thank you everyone for your input...I finally got it to work!!!
