Music Moving iTunes from Mac to PC
Discussion in 'General' started by IamJudd, 2 Mar 2013.
  1. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    I currently have all of my iTunes files on an external WD Mybook 1TB drive. I plug it into my MacBook Pro when I want to listen to music and, as a result, usually can't be arsed so load up Spotify or YouTube instead.
    I thought it would be easy to de-auth my MB Pro and just plug the drive into the PC but unfortunately, the drive was formatted by the Mac and the files aren't visible in Windows 8.
    I don't think I could disregard iTunes altogether as I have an iPad, Touch and a couple of Nanos but I do want to move my files to the PC to take advantage of the Zune Software which, well, looks really nice.
    What would you suggest to be the easiest way of moving 1TBs worth of files to my PC please?
    Thanks in advance,
    Ian
  2. RedFlames
    23 Apr 2009
  3. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    Thanks red but my external drive is not recognised when plugged into the Windows PC...
  4. RedFlames
    23 Apr 2009
    only options i can think of are:
    Copy it to the Mac, then format the external to something readable by windows
    Copy/Share it over the network using SMB
    Use Home Sharing in iTunes
    [Re-]Download any iTunes purchases on the PC [obviously only works for stuff bought off itunes]
  5. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Macdrive for the Windows PC.
    Chances are it's HFS or HFS Journaled (I can never remember what Macs use these days..), which Windows won't natively read.
    MacDrive should do the trick - I use it for just that.
  6. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    Thanks guys... Shall try it tomorrow!
