Windows moving xp
Discussion in 'Software' started by rick, 23 Apr 2005.
  1. rick
    rick What's a Dremel?
    4 Mar 2005
    i'm about to get a new hdd for my xp pc and was wondering if i'll be able to copy xp over to the new faster drive without having to install it again on the new drive. can anyone help?
  2. Springs
    Springs Boing boing
    29 Aug 2004
    yes its very easy to do... you wil need a program called Partition magic or any program that deals in partitions (someone might be able to show you a free piece of software that can do the same thing) and you should be able to copy your windows partition over to the new disk pretty easy :D
  3. andyunder
    andyunder What's a Dremel?
    22 Mar 2003
    its maxtor maxblaster on maxtor drives or the are others. look at the drive manufature website for suport software
  4. tk421
    tk421 Idiot.
    15 Jan 2002
    ghost will work too - just make a partition on the new drive the same size as yur old drive, and ghost it over.
  5. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    i second norton ghost use it at work all the time saves so much time.
  6. gmail
    gmail What's a Dremel?
    16 Feb 2005
    yep, ghost is the best
  7. advance
    advance What's a Dremel?
    18 Apr 2005
    Never used ghost, but I can assure you that Partition Magic works well!
  8. Pita^Norf
    Pita^Norf What's a Dremel?
    26 Jul 2003
    Never used Partition Magic (for cloning), but I can assure you that ghost works well! :D
  9. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Let's not make this a pissing contest, boys...
    My favorite is Partition Magic.
