Mozart tx massive water cooling mod. small update 3-10-07
Discussion in 'Project Logs' started by khitsicker, 8 Mar 2007.
  1. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    You need to sell me that Storm...
  2. khitsicker
    khitsicker What's a Dremel?
    29 Jun 2005
    finished the rad support
    small update .. finished the rad support plate. filed and sanded down all the rough edges and finished it with some 320grit on my orbital sander. i dont know if ill keep it this way though it looks like the dremel slipped more thimes then i though and there are some pretty rough gouges in it. ill prolly end up filling them with jb weld and painting it matte black.
    ill have more monday when im off from work. but ill give you a sneak peek at another project of mine thats nearing completion as well
  3. wbdog206
    wbdog206 not me
    15 Jan 2007
    is that an apple mac full of water?
  4. khitsicker
    29 Jun 2005
    >.> <.< quite possibly
  5. V3ase
    V3ase What's a Dremel?
    25 Jan 2007
    MMMMmmmmm im love'in it :]
    Keep working , w8 for updates
  6. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    are you making an aquarium? if so, that is completely ant utterly badass.
  7. MixWizard
    MixWizard What's a Dremel?
    16 Jan 2007
    lmao thats an idea, never thought of that. Thought could have been a big ass reservoir
  8. wbdog206
    wbdog206 not me
    15 Jan 2007
    ether way that is slick.
    i like the look of the TT Mozart good job
  9. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    Thats what i am doing with an old mac shell i have lying around, it is one of the aqua blue shells though :)
    The project is looking good so far, keep it up :)
  10. ottzen
    ottzen What's a Dremel?
    28 Nov 2006
    Ohh! ohh, I know what it is!!
    An aquarium AND a reservoir :D :D :naughty:
    //ottzen
  11. casey_cole
    casey_cole What's a Dremel?
    16 Dec 2006
    I'd like to see a goldfish get sucked through a water block :p
    CC
  12. khitsicker
    29 Jun 2005
    lol i had honestly not thought about making it an res.. and somehow i dont think the fish would like the additives.. not to mention all the bio matter that would get sucked into the water block
  13. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    maybe use the apple as an aquarium but put a resavoir suspended in the middle so it is effectively an aquarium and a resavoir
  14. TMM
    TMM Modder
    12 Jan 2004
    For thermaltake watercooling, which is rubbish ;)
  15. khitsicker
    29 Jun 2005
    pretty much. i knew from the start id be modding the back plate. these thermochill rads are so damn big. theres only about a half a centimeter of clerance on the barb side. also i dont know if it comes out in the pics but on the bottom of the case there are pairs of holes evenly spaced. it looks like its for a pump but they shure as heck dont line up with the iwaki mount.
  16. Slatter
    Slatter Mesh Addict
    16 Feb 2007
    love the mozart man.... good choice
  17. Guest-23315
    Guest-23315 Guest
    very good selection of water-cooling componets.
  18. khitsicker
    29 Jun 2005
    thx.. i have alot more on the waywhich is whats holding up progress currently. they will arrive erarly this week though so i can get back to work
  19. pantera989
    pantera989 What's a Dremel?
    14 Jul 2008
    just wondering what you have againsit thermaltake watercooling?
    i have the steel versoin of this case with 2x 12x24cm theraltake rad's which fit in fine with no modding with suggests thermaltake designed the back panel around its rads.
    nice job with fitting differnt rads in though? just wondering how 2 of those smaller rads compare to a single 12x24cm rad?
  20. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    I've heard bad things about TT's liquid cooling, so I don't touch them:p TT cases aren't that bad for modding though (so I've been told)... prefer the look of Lian Li's though
    My two cents on the subject... mod looks good so far, I'm gonna keep an eye on it:)
