Scratch Build – In Progress Mr. Wallmount project - Finished 15-02-2016
Discussion in 'Project Logs' started by Cown, 30 Nov 2015.
  1. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Fun looking project.
  2. ChrisHowell
    ChrisHowell What's a Dremel?
    29 Aug 2015
    Progress is looking good. Random question on the window mounts, are those supports freely available? What are they called? Cheers!
    Looking forward to see more parts go in :)
  3. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks guys :)
    #22 I would think so :D Had a hard time finding the right length here at home, but ebay was a big help, just search for Stainless Steel Glass Standoffs, and they should pop up, pretty cheap too :)
  4. Cown
    Cown Minimodder
    25 Feb 2012
    Update 15-02-2016 - FINISHED
    Hey guys :D
    Time for a final update!
    Just finished the project, and I'm pretty happy with it :clap:
    Cable management:
    Getting there:
    As clean as I can get it :D
    Plexi mounted to the stanoffs:
    Final pics of the media center, hanging in the man cave, ready to stream teh moviez :hip:
    Thats it!
    As always, thanks for looking guys and sharing your opinions :D
    Now I'm off to build the next one! :dremel:
  5. Dr. Coin
    13 Sep 2013
    The case looks good. I love your alignment of the pump.
  6. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks mate, glad you like it :D
  7. Cheapskate
    13 May 2007
    That came out pretty good.:thumb: I hope the plexi corners are above head-stabbing height.
  8. Cown
    Cown Minimodder
    25 Feb 2012
    Thanks cheaps :thumb: glad you like it.
    No worries :D there won't be any chance of head injuries. I've mounted cinema chairs a littler further to the front to where the case i mounted, so there is about 50 cm of free "head" space when standing or sitting, short or tall :D
