Scratch Build – In Progress Mr3D - Project Tatami (mATX computercase from scratch)
Discussion in 'Project Logs' started by Mr3D, 22 Mar 2015.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    Love the flush fit windows. :D
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    love the milling :rock:
  3. noobas4urus
    noobas4urus What's a Dremel?
    7 Oct 2014
    I'll gladly give you two more minutes of my time for that. Nice buttons on the Aquaero and the window inserts are top notch.
  4. Cheapskate
    13 May 2007
    2 minutes? I spent a good 15 on this update.:D I'm still ogling.
  5. galletabah
    galletabah What's a Dremel?
    15 Jun 2015
    the best mod i ever seen
  6. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
  7. Mr3D
    Mr3D What's a Dremel?
    23 Dec 2011
    I knew you would. :D
    Thanks guys! :rock:
    LOL!
    Agreed, it needs some polishing. Polycarbonate is not as scratch-resistant as acrylic.
    Time for a small update!
    Bought myself a graphics card! Not a regular one, tho... A Quadro M4000. :jawdrop:
    Well, the thing is, I never play games on my computer, tho I like to draw in CAD, so the choice was easy. :cooldude:
    Right now I'm running 2x Quadro FX4800. I'm really happy with them, but it will be really nice with a upgrade!
    24-pin cable, done! Took some time to do it, but turned out great in the end. :)
    Lathed and polished some spacers for the flow-sensor. :thumb:
    That's all for now. Another time, another update. :)
  8. Cheapskate
    13 May 2007
    There will be a waterblock for that, right?:D
    I can hear those cables creaking like leather pants from here.
  9. Mr3D
    23 Dec 2011
    Indeed it will!
    Isn't that a nice sound? :D
  10. B NEGATIVE
    8 Aug 2011
    Another barefoot modder......we need to start a club!
    Dunno about the leather fetish tho...not while rubber is still around.....:eeek:
  11. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Fantastic work, can't beat the accuracy of cnc.
  12. rogergamer
    rogergamer What's a Dremel?
    3 May 2015
    I wish I had access to all your industrial machines (and actually know how to use them haha)
    BTW: how durable is the anodization on your aluminum panels?
  13. B NEGATIVE
    8 Aug 2011
    FTFY
  14. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Do not forget the guy doing the programs for the CNC, and mounting the raw material. If he ****s up there, you could have better accuracy with a spoon.
    contrary to popular belief, you do not just throw a step file into the computer and press "go".
  15. B NEGATIVE
    8 Aug 2011
    Yup.
    Sadly.....
  16. Lehani
    Lehani What's a Dremel?
    27 Jun 2012
    sweet made :D
    love the side windows :D
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    24 pin cable looks good to me.
  18. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    :eeek: :eeek: Damn. Just damn. :thumb: :thumb:
  19. Teelzebub
    27 Nov 2009
    Yup so true the CNC will do exactly what's it's told if it's told wrong it will do it wrong.
  20. Cheapskate
    13 May 2007
    @Pope - NOW you tell me?
    @Teel - Sometimes mine does what it wants, not what it's told.:worried: Although I think I got that fixed since I started the Turnip.
