MS Access Help...?
Discussion in 'Software' started by jopers1986, 22 Sep 2008.
  1. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    Right, I'm making this database to help with a job costing system (recording employees times week by week using dates) using 3 different pay rates which are individual to each employee.
    I'm getting on fine with it, but i've hit a problem! I need an effective way of entering in the hours worked on each pay rate.
    It needs to be done with the dates run along the top as column headers, then each employee down as a row header, showing their payrate as well (a max of 2 for each week!
    It's all rather complicated and tbh, i've started to rip my hair out over it, does anyone have any good ideas?
    thanks
    Rich
  2. jopers1986
    7 Jan 2005
    Also, is it possible to use a cross-tab for data entry?
  3. koola
    koola Minimodder
    11 Jul 2004
    If I understand correctly, you want to list each employee as a row against a week and show their pay against their respective individual payrate?
    I don't use MS Access, but I do use MySQL for web development so I did a quick test.
    DB tables:
    Code:
    pay_rates
    | id |  emp_id  |  group_id  |  hours  |    date    |
    | 01 | 0566     | 01         | 30      | 2008-09-22 |
    | 02 | 0566     | 02         | 5       | 2008-09-22 |
    | 03 | 0566     | 03         | 2.5     | 2008-09-22 |
    | 04 | 0567     | 01         | 35.5    | 2008-09-22 |
    | 05 | 0567     | 01         | 2       | 2008-09-22 |
    | 06 | 0566     | 03         | 37.5    | 2008-09-22 |
    pay_groups
    | id |  group | pay     |
    | 01 | A      | 6.50    |
    | 02 | B      | 8.50    |
    | 03 | C      | 9.75    |
    Then your sql would be like:
    Code:
    SELECT pr.emp_id, SUM(pg.pay * pr.hours) AS earned, pr.date
    FROM pay_groups pg, pay_rates pr
    WHERE pr.group_id = pg.id
    GROUP BY pr.emp_id, pr.date
    Result:
    Code:
    Array
        [emp_id] => 566
        [earned] => 365.625
        [date] => 2008-09-21
    Array
        [emp_id] => 566
        [earned] => 261.875
        [date] => 2008-09-22
    Array
        [emp_id] => 567
        [earned] => 247.75
  4. koola
    koola Minimodder
    11 Jul 2004
    doh!
