Development MS Access VB find, and save file
Discussion in 'Software' started by jopers1986, 23 Jul 2013.
  1. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    Hi all!!
    Long time since i've posted on bit-tech, have turned into a lurker!
    I'm having a head ache with a database i'm makeing for work, and am now stumped and was hoping someone out there would be able to help.
    My Visual Basic is... well... basic!
    I have a the database stored on a networked drive, and i need the users to be able to find a file, ideally using the standard windows open dialog box, (but not actually open it, just find store the file location to use) then rename it, save it to a standard location on the network drive and log it in a table on the database.
    I've found the below link to the OpenFile function and have tried it, but really can't get it to work...
    http://access.mvps.org/access/api/api0001.htm
    Can anyone help me pleeeease treating me as an idiot!?!?!?!?!
    Thanks!!!
  2. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    why do they need to rename it and store it on the server, you could write a script to do that a lot easier?
  3. jopers1986
    7 Jan 2005
    That's ideally what i'd want the code to do, re-name the file after ID field in the open DB record and save it in a central location... i've got odds and ends, but can't patch anything together
  4. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    First what you need to do is open your connection to your table call the file dialogue function and store the outputs of that to your table.
    Code:
    Dim db as databse
    dim rs as database
    dim sfile as string, spath as string
    set db = currentdb
    set rs = db.openrecordset("select * from [yourtable]")
     With Application.FileDialog(msoFileDialogOpen)
     .AllowMultiSelect = false
    .InitialFileName = "\\default\location
    .Filter 'if appropriate
    .Show
    sFile = .SelectedItems(1) 'might be 0
    sPath = .SelectedItems(1).path 'might have made that up
    end with
    'feed file and path to your table.
    rs("File") = sFile
    rs.update
    end function
    I can't think how to do the copy off the top of my head, but the code above isn't tested so someone will have a solution (hopefully) by the time you get that coded up properly.
  5. bsp
    bsp Minimodder
    25 Dec 2010
    Can't recall if it's fixed or not.. but I think there was a vb bug for "save as".. so careful with that one.
