News MS issues emergency IE patch
Discussion in 'Article Discussion' started by CardJoe, 30 Mar 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    You mean there are still people who actually use IE?
  3. Zayfod
    Zayfod What's a Dremel?
    6 Jun 2005
    it can be quite hard not to, what with it being integrated into Windows and all.
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    Get up, patch up! Don't give up the fight! Get up, patch up! Finally doin' it right!
  5. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    True, even the recent Choose Your Browser application ran in IE.
  6. tripwired
    tripwired Deploying Surprise in 3... 2...1...
    12 Feb 2009
    It's hard to break away from Internet Explorer with bespoke software (designed with only IE support in mind) used in a lot of companies. Our booking system at work only functions inside IE6 or IE7, I'm still waiting on them to implement IE8 support, nevermind Firefox or Chrome :wallbash:
  7. Fizzban
    10 Mar 2010
    It was meant with a little humour. Also I don't think its hard not to use it. Whenever I do a new windows install I have everything I need on another HD ready to go..including a Firefox.exe. And even if you need to use IE to download another browser..you use it for all of, what? A minute?
    You have my condolences then. I avoid IE like the plague.
  8. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    My main browser of choice has become Chrome, although it took me a while to get used to it's bare bones look. I only use Firefox now when I have the need to make use of specific plug ins. IE 8 very rarely see's the light of day except on those rare occasions when something simply doesn't work in either of the other two.
    Opera has always had it's appeal, but for some reason I have never really been able to gel with it. With Chrome, my only real niggle is that when it is not full screen that it does not like being right up against the edge of the screen.
  9. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    Also you have to remember that some apps use IE within them - for example Steam uses 32-bit IE.
  10. Psy-UK
    Psy-UK What's a Dremel?
    22 Jan 2009
    Thankfully, the Steam 2010 UI beta uses Webkit.
  11. Shagbag
    Shagbag All glory to the Hypnotoad!
    9 Nov 2006
    Or they could just bite the bullet and switch to Firefox, Opera, etc. and avoid the future 'headaches'.
  12. Farfalho
    Farfalho Minimodder
    27 Nov 2009
  13. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    But I love Internet Explorer...its like a lovely big bag of chips soaked in salt and vinegar...mmmm and with scraps too.
  14. macroman
    macroman The One
    3 Sep 2001
    From an IT professional view, random updates are nothing more than a slight inconvenience. Any business with any thought towards protecting itself will be using tools such as WSUS or Altiris etc to protect itself. so no news here. Move along.
  15. Ataraxia
    Ataraxia <b>OOH BABY!!!</b>
    12 Mar 2001
    this is pretty much true. i've had instances where an official update has caused problems other than what it is supposed to fix but those have been quite rare. Not applying a patch is almost certainly worse than applying it. Large scale operations are always better testing patches against their own setup before wide scale deployment but that is a given, security updates are best applied as soon as is viable.
  16. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    IE = Idiots Explorer
  17. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Glad to know Microsoft's taking extra effort for serious patches.
  18. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    You're joking right!? You can't open firefox without it doing more bloody updates.
  19. Pookeyhead
    30 Jan 2004
    It takes a few seconds, and you're always up to date. I see no problem with the frequent updates.
  20. Shagbag
    9 Nov 2006
    I've never experienced anything like that, despite having my options set for automatic updates. Maybe a case of YMMV.
Tags: Add Tags
