Modding MS optical mouse - can it be done??
Discussion in 'Modding' started by petemcrae, 19 Mar 2001.
  1. petemcrae
    petemcrae The first modder here
    12 Mar 2001
    I want a blue led optical mouse.
    I have the MS optical mouse and was wondering if anyone has hand on expereince or can guide me to a tutorial.
    Will the blue LED work and be bright enough??
  2. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    does werk!
  3. Koolvin
    12 Mar 2001
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    cool .... shame i dont have an optical mouse!
  5. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    I can also add (from experience) that this doesn't work very well on the Intellimouse Explorer.
    It'll work ok on the optical lens, however the LED at the back which gives the very cool red glow is obscured totally by the red plastic.
  6. Pigeon
    Pigeon What's a Dremel?
    13 Mar 2001
    any Pics anywhere of the Explorer?? MS should sell them in Blue I think.
    /me writes to Microsoft and asks.
    My Explorer is lookng rather tired at the moment.
  7. Koolvin
    12 Mar 2001
    There is actually a Logitech mouse that has a Blue Led on the top and a red one for guidence systems! I have heard that its a very good mouse.
    If anyone buys one tell me what you think!!!!!
  8. moose
    moose What's a Dremel?
    12 Mar 2001
    I've seen said Logitech mouse at a lan before. It looked really good, and all in all I was pretty impressed with it. If i didnt have my Explorer already, I'd go for it definatly :)
  9. SuperScrubber
    SuperScrubber Mad Chemist.....buwahahaa
    12 Mar 2001
    My m8s got the logitech one whereas I went for the M$ one. IMHO despite not being blue :( the intellimouse is better. The logitech has this really gay rumble back thing going on that makes it vibrate as you go over buttons, links or whatever which sounds Ok but is actually really annoying, he may have just have it set up to do that for everything though. Plus the build quality isnt as nice either, the M$ feels like it would survive a 100ft drop whereas I couldn't say the same of his logi! Its also worth bearing in mind that in both cases the amount of light you actually see is very little although I still want mine to be blue!!!:D
