Hardware MSI 770-C45 Motherboard Review
Discussion in 'Article Discussion' started by Tim S, 17 Sep 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    Hmmm.
    I spent the same amount of money (well OK...£57) on a Gigabyte AM2+ M720-US3 for my budget rig which is 140w rated for the 965 , has a nicely OC'ed Northbridge to 2400, , DDR2 running @ 1100, ACC which unlocked the 2 cores on my 550, which is now running at 3.7Ghz @ 1.45vlts in Quad core mode and is as solid and stable as you could wish for.
    The ONLY supposed advantage i can see to this board is DDR3 support, which in real life scenarios, isnt much of an advantage at all....certainly not in games to any noticble degree.
    Seems to me the US3 is more of a safe bet than this.
  3. Sheiken
    Sheiken Wat?
    9 Jan 2005
    For me this is what overclocking is REALLY about! Not purchasing the most expensive gear you can get your hands on, but making sound choices when it comes to components regarding cost and overclocking potential! Aint to school like old school!
  4. Ross1
    Ross1 What's a Dremel?
    15 Feb 2009
    This combined with the cheap and chearful athlon X4 620 or 630 surely makes for a fantastic value combo. Be very difficult to beat it in terms of price/performance.
  5. stonedsurd
    11 Mar 2009
    Should that not be 'appendages'?
  6. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    +1
    and a Radeon HD 5850
  7. Scootiep
    Scootiep Minimodder
    9 Aug 2007
    Quoting from your P55 GD65 review "While MSI is not alone in including the PS2 mouse option, again we wonder why. Surely no one uses this now, where as least PS2 keyboard is good for BIOS compatibility." Did you guys change your mind on this one? From that review, it seemed like you were completely baffled and annoyed that they included a PS2 mouse but here you don't even give it a second glance. Don't go getting soft on these manufacturers now. IMO, they should have and could have easily included a 6 pin 1394 and an S/PDIF for compatibility. Since I use both of those techs frequently, that is what is preventing me from purchasing this otherwise very nice board.
  8. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    Thats why I like my ASUS M4A785TD-M Evo. One PS2 which will never get used, two USB in the place of the second PS2. S/PDIF and firewire on the backplane.
    and WTF, serial port? Do home users need these?
  9. Ross1
    15 Feb 2009
    the only thing ive used the serial port for in the last couple of years is for flashing liteon 360's.
  10. Guest-16
    Guest-16 Guest
    For £50, I couldn't care less. It's easily ignored.
    For £130, I expect the right features on the latest board and product design.
    Firewire costs money - the board doesn't have it. I've no idea why there's a serial port though, I imagine the board is made as general as possible for all applications: emerging markets and scientific applications may require it.
  11. EvilRusk
    EvilRusk What's a Dremel?
    23 Jan 2006
    Well thank goodness for that. With all these ridiculously expensive boards I am glad to see something much more affordable popping up. So it doesn't look like Optimus Prime - so what! The £150 saved could go on transformers to decorate your case with...
  12. Mante
    Mante What's a Dremel?
    13 Dec 2005
    At this Price Gigabyte GA-MA770T-UD3P Cheesecake!!!!
  13. Guest-16
    Guest-16 Guest
    CustomPC tested it in a recent roundup. It wasn't as good.
  14. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Nice review, looks like MSI have some quality AM3 boards out atm.
Tags: Add Tags
