Gaming MSI 890GXM-G65 micro-ATX Motherboard Review
Discussion in 'Article Discussion' started by Claave, 17 Mar 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    such a disappointmend, i wanted to build a SFF gaming pc with this
    MSI 890GXM-G65
    amd 965 BE
    2x ati 5770's
    corsair h50 + lian li v351b
    home gigabyte comes out with a similiar matx board but good for overclocking
  3. dec
    dec [blank space]
    10 Jan 2009
    Makes me wonder why theres a core disabling feature. Did you guys try it to see if MSI renamed it that when is really a core unlocking feature? When's 890FX (and 900SB?) coming out?
  4. Claave
    29 Nov 2008
    From the review:
    Finally, don't be confused by the Core Control menu - it's not there to unlock the extra cores of a Phenom II X3 CPU, as MSI does not and will not feature this option. Instead, this menu lets you disable CPU cores. This is only of use if you’re trying to break CPU frequency records by only running one core (and thus lowering the thermal output and power draw of your CPU), so it’s very strange to see the option in a modest micro-ATX motherboard’s BIOS.
  5. Jipa
    5 Feb 2004
    A board like this might well make it into my next work/main computer. The performance of the 965 BE is easily enough for me, no need to go i7, and the 890/850 combination has all the features I'll ever need. Too bad this apparently isn't the mATX 890GX-board worth getting.
Tags: Add Tags
