Hardware MSI 970 Gaming Review
Discussion in 'Article Discussion' started by Dogbert666, 21 Aug 2014.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    Hell of a good option if you want to build a PS4/Xbox One beating gaming PC on the cheap:
    Bit Fenix Neos Case £30
    MSI 970 £70
    FX 6300 £70
    Crucial M100 256GB £80
    500GB 7200rpm £40
    AMD 2GB Radeon 270 £120
    8GB Ram £60
    450w PSU £50
    ..for about £500 that's good enough to play anything out there at 1080p on medium/high settings.
    Bargain.
  3. Dogbert666
    17 Jan 2010
    Corsair M100? :p
  4. Gareth Halfacree
    4 Dec 2007
    Plus £70 for the OS (£50 if you're a student), don't forget.
  5. Hustler
    Hustler Minimodder
    8 Aug 2005
    ..derp, still hadn't finished my morning wake up coffee.
    Corrected.
  6. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    Thinking of the Corsair H100i while typing Crucial M100? ;-)
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    If you can get by with so little storage why bother with a mechanical hdd at all?
    The 512GB Crucial MX100 has dropped to just below £150.
  8. Dogbert666
    17 Jan 2010
    Hehe, almost, it's the MX100 xD
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
  10. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    just find it hard pressed to use AMD high end CPUs that are barely faster then a C2D and use 2-4 times power then a C2D
    the only benefit you got with AM3 is DDR ECC support on the cheap (ASUS mobos only, other mobo makers seem to hide the ECC enable option) but i can Buy Old HP workstations with Nvidia Quadro card fitted for under £200 (the standard config is normally ECC)
Tags: Add Tags
