Hardware MSI, AMD 890GX and Core Unlocking
Discussion in 'Article Discussion' started by Sifter3000, 16 Apr 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. phuzz
    phuzz This is a title
    28 May 2004
    If this is the sort of reporting we're going to get from Tiwan, then I'm glad you're out there Rich.
    um, that sounded nicer in my head...
    So why doesn't Intel try selling triple core CPUs? (or other CPUs with failed cores)
  3. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    sweeet :) i'd set my hopes on this board but after your original review i'd started looking elsewhere
    I'll def pick one up now, throw it in a lian li v35ib with 2x5770's
  4. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Possibly because they don't need to.
    They have such a span of price points, that releasing a quad with a failed core, at a discounted price, would tread on the toes of one of their other CPU's.
    On topic, the new bios looks great, and seems to help push AMD back towards a possible alternative to the Intel route
  5. dec
    dec [blank space]
    10 Jan 2009
    Um rich
    14 * 200 = 2800
    14 * 240 = 3360
    3360 - 2800 = 560, not 536 like on the 1st page.
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    It did but I still agree. :thumb:
  7. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    So, in spite of this being potentially a good board now (assuming performance doesn't degrade when ironing out the last few bugs) this board or even the ASUS one won't actually make it into the buyer's guide. I'm eyeing up an AMD system now, but only because the cost of CPU + motherboard + RAM is small. If motherboard manufacterers can't get a cheap overclocking board with core unlocking out the door I'll only be looking at the last generation of boards.
  8. Denis_iii
    1 Jan 2007
    why wouldn't it make it into the buyers guide?
    note: how about a SFF section in the buyers guide Bit-tech?
  9. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    [eurl=http://www.bit-tech.net/hardware/motherboards/2010/03/02/asus-m4a89gtd-pro-usb-review/1]Asus M4A89GTD[/url]
    last page remove the e from the brackets
  10. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    It won't make it into the buyer's guide because AMD only make it into the budget build, and this board isn't budget. It might be an ok buy for someone who already has an AMD setup, or when Bulldozer comes, but right now Intel have them beat on performance for value at the higher price points.
  11. Primoz
    Primoz What's a Dremel?
    22 Dec 2007
    'Radeon 5870 1 GB' My ass, that's a Lightning ^^
  12. Initialised
    Initialised What's a Dremel?
    23 Jul 2009
    M4A78LT-M LE: unlocks 550, runs and overclocks 1055T, probably unlock 960T too.
  13. Guest-16
    Guest-16 Guest
    That's what I said in the text. It was clocked down to stock speeds.
  14. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    That board's a 760G, like I said manufacterers need to do something with the new 8xx series to get them up to the same level of funcionality as the 7xx series. Almost all the 7xx series had core unlocking, but now only a handful of 8xx series have it. What's the point of trying to save money with AMD and unlocking cores if you now have to buy one of the top end motherboards to get that feature?
    Still, this doesn't really bother me. The only thing the 8xx series brings that I might want is USB3, and I haven't got a USB3 device and don't see myself getting one for a good while yet. I'll be happy getting a 7xx series when I come to upgrade (and spend the cash I save on a beefier GPU ^^)
  15. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Is there a review comming of the Asrock 890GX Extreme3? It's cheaper, looks better and has a unlocking chip.
    I wonder about the performance compared to the Gigabyte GA-890GPA-UD3H, MSI 890GXM-G65 and Asus M4A89GTD PRO/USB3.
  16. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    ASUS in talks with nvidia for SLI licensing on 890FX?
    http://www.hardwarecanucks.com/foru...rmula-am3-890fx-motherboard-sneak-peak-3.html
    Hopefully 890FX will bring stability and a performance edge to the 4GHz x6 overclocks happening in secret labs throughout the hardware community as we speak.
    Unlocking was 'blocked' on 890 for the same reasons as that bloke left a next gen Apple in a tech journo's lap. To get us talking about it and drum up AMD sales.
  17. Cyberpower-UK
    6 May 2009
    I think you just answered that!
    760G boards are dirt cheap.
  18. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    My whole point is that you can get a cheap 7xx series board with core unlocking, but if you want the latest 8xx series you have to splash out to get that feature. If I do end up getting AMD, I'll definitely be looking at something like the M4A78LT-M LE with the 760G chipset. I'd prefer to get a similar model of an 8xx series though, but there's no point without core unlocking.
  19. Cyberpower-UK
    6 May 2009
    Cheap low end 800 series board with unlocking and turbo tweaks will follow the high end stuff that's about to launch.
  20. Krayzie_B.o.n.e.
    Krayzie_B.o.n.e. What's a Dremel?
    2 Aug 2009
    We all love spending countless hours tweaking, overclocking, and unlocking but AMD should just make a chip that can better compete with Intel without all the gimmicks. At this point Intel is just blowing AMD out the water as the Phenom is a bottleneck whore with or without overclocks and unlocks.
Tags: Add Tags
