News MSI announces CPU Guard 1151 Skylake shim
Discussion in 'Article Discussion' started by Gareth Halfacree, 17 Dec 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Doesn't look like a shim to me, looks like a whole replacement retention mechanism.
    It's definitely treating the symptoms rather than solving the problem though: don't use heatsinks with stupidly high clamping forces in the first place. Even if they don't cause visible physical deformation of the substrate, stressing the substrate is a Bad Idea in any case. The die itself is only held to the substrate by very small solder balls (far finder than normal BGA pitches), and these can easily be fractured. The RRoD, YLoD, and many laptop GPU recalls from both AMD and Nvidia have been due to fractured solder balls between the CPU (or GPU) die and substrate.
  3. Guest-16
    Guest-16 Guest
    No, the root issue is that Intel is continuing to cost down their CPU packaging while their cost continues to rise. It's BS.
    andrew8200m likes this.
  4. jb0
    jb0 Minimodder
    8 Apr 2012
    Welcome home, Athlon XP shims! It's been too long!
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    The issue is that some after market coolers didn't follow Intel specifications, if you fit R rated tires to your car you can't blame the tires when they fail if you exceed 100Mph.
  6. jinq-sea
    15 Oct 2012
    With nudie pictures on them? :eeek:
  7. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Gives a new meaning to the term "blow out"
  8. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    1.6mm, barely legal.
  9. jinq-sea
    15 Oct 2012
    Hahahahaha
