Reviews MSI B450M Mortar Review
Discussion in 'Article Discussion' started by bit-tech, 4 Sep 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. adidan
    25 Mar 2009
    Been toying with a Zen+ setup (maybe waiting for Zen2 though) and this seemed to be the best of an otherwise generally bad bunch of matx B450s, nice to see this review too.
    As for an M.2 heatsink, going by other tests i've seen it looks like ones bundled with MSI in the past actually trap the hot air underneath and increase the temperatures there.
    How was the BIOS btw?
  3. Combatus
    16 Feb 2009
    Just added links to out previous MSI BIOS analysis!
    Depends on the SSD. I think Gamer Nexus used a Kingston SSD and this had components on both sides so yes, unless you cool it underneath too it will heat up. Samsung SSDs on the other hand, not only have components on the top side only, but the underside also has a thin copper-backed label that acts like a heatsink so you don't need to worry too much there.
    adidan likes this.
  4. adidan
    25 Mar 2009
    Awesome, thanks for both the links and pointers :)
    Actually, really helpful re the M.2 info.
  5. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Power consumption numbers look off.
  6. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    The idle numbers you mean, i thought the same, maybe something didn't enter a sleep state.
  7. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Potentially a spectre or meltdown related thing although I can't be certain as I didn't test.
  8. Combatus
    16 Feb 2009
    Seems to be an MSI B450 issue - I got the same results with the B450 Tomahawk I had to hand as well.
  9. battouter
    battouter What's a Dremel?
    22 Nov 2018
    these power consumption numbers don't look right. you might have a faulty mobo right there.
Tags: Add Tags
