News MSI ECOlution: powering fans without electricity
Discussion in 'Article Discussion' started by Tim S, 29 Feb 2008.
  1. TurtlePerson2
    TurtlePerson2 New Member
    19 Dec 2006
    Yea, I thought of something like this, except to power a CPU, but that was more of a theoretical thing, this is real engineering.
  2. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Idea:
    Unhook the fan. Hook it up to a generator, which is hooked up to a small heater / TEC instead of the chipset.
    Free energy !
  3. Guest-16
    Guest-16 Guest
    The energy produced is so minute though and with every conversion you lose efficiency.
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I want one of these so much... but I don't know why.
  5. karbonKid
    karbonKid Member
    5 Jul 2006
  6. Herr_SturmGeist
    Herr_SturmGeist New Member
    24 Apr 2005
    The 60C is a bit misleading, Sterling engines work on temperature differentials so it really depends on what the temperature of the air around the cooler is, though 60C is probably calculated on the expectd average of that air. Way cool idea nonetheless.
  7. cobalt6700
    cobalt6700 Active Member
    17 Oct 2005
    very cool idea, but 60c seems a bit much really,
    ive held sterling engines that run off the heat of the palm of your hand....
  8. kHAn_au
    kHAn_au New Member
    12 Dec 2005
    Kudos to MSI for actually designing it and making it work.
    I've looked at the Stirling engine for similar uses previously but dismissed it as 'over engineered' for the task.
    Maybe they got a uni student on placement to do it....
  9. naokaji
    naokaji whatever
    8 Dec 2006
    the point behind making it only work above a certain temperature is having passive cooling most of the time, its not a technical limitation.
  10. Bbq.of.DooM
    12 Feb 2005
    Way to pop my bubble.
    I know, but still.
  11. Orlix
    Orlix New Member
    9 Dec 2007
    This is great... I would agree with many people that this might not be the best slution for most people, even it might not be worth it due to its 60° limitation. The important point here is that MSi is trying new technologies and hopefully this will encourage others to experiment and bring innovation.
  12. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Stirling, Stiring or Sterling?
Tags: Add Tags
