Hardware MSI GeForce GTX 1050 Ti Gaming X 4G Review
Discussion in 'Article Discussion' started by Dogbert666, 7 Nov 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. dontlookatme
    dontlookatme What's a Dremel?
    18 Feb 2015
    Hi & thanks.
    a point - TW: Warhammer - I noticed that for NV Pascal cards, the DX11 performance may be considerably higher than in DX12 mode. Maybe you should check the best vs best in games that have both DX11/OpenGL and Vulkan/DX12 modes
  3. Harlequin
    Harlequin Modder
    4 Jun 2004
    ocuk have a powercolor RX 470 for £169 , which makes this @ £165 redundant imo
  4. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    Even if you take the cheapest Ti on Scan it's just £30 less than the cheapest 470. This is genuinely one of those cases where if you can hold on and go the small extra £££, you will get a whole lot more performance.
  5. Taua
    Taua What's a Dremel?
    20 Sep 2014
    Agreed, just not seeing the point of this card considering current prices, it's much too expensive.
  6. mute1
    mute1 What's a Dremel?
    16 Sep 2009
    Article: 'Following a major test system fail ...'
    The word is 'failure'. Stupid meme talk...
    Otherwise, good review! :)
    EDIT: It's worth keeping in mind that the pricing in other parts of the world makes the 1050 Ti a better value proposition, although perhaps not this version.
  7. flipman
    flipman What's a Dremel?
    21 May 2010
    This morning I checked on my local website for buying GFX cards and I discovered that even a GTX 1050 2GB is more expensive then a GTX 1060 3GB. Stuff is weird atm so I can just hope its just here in South Africa.
  8. Vault-Tec
    30 Aug 2015
    Aye you'd really have to hate AMD to go anywhere near this.
  9. nimbu
    nimbu Multimodder
    28 Nov 2002
    Personally just grabbed the Zotec Mini 1050 Ti while I am in the US for work.
    Total cost including sales tax was $152 at todays rate not a great saving, however I was using money that I had changed a little while back at much better than todays rate. ($1.44 to the pound).
    So I feel I got a good deal, this is to go into my OSMI case build, coupled with a i5 Haswell T variant CPU.
    Cant wait to get back and start putting this all together!
Tags: Add Tags
