Hardware MSI GTX 285 HydroGen OC Review
Discussion in 'Article Discussion' started by Lizard, 9 Jul 2009.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    What i see:
    All of the Game benches are won by the ATI HD4870 X2 2GB
    The only Application bench (folding at home) is won by Nvidia cards
    And in the power consumption part the ATI HD4870 X2 2GB is left out of it. (probably because it has higher power usage then anything else)
    IMHO you should have left out the ATI Dualcore card completely, now people will get the wrong idea. Without it Nvidia wins.
    Infact you should have left out all the ATI card and other Nvidia cards and only compare the Non watercooled GTX285 to the MSI watercooled GTX285.
  3. Baz
    Baz I work for Corsair
    13 Jan 2005
    If we didn't include the HD 4870X2, it would make for an extremely misleading article. It's in there to demonstrate that for less cash, you can get a significant amount more performance. An HD 4870X2 can be had for less than £250 - thats less than the watercooler GTX 285. Of course, the watercooled card will be quieter and cooler, but if all you want is performance, a reader needs to know what else is out there - that;s why we have all these fancy graph engines and stuff, so show you what else is available!
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Shouldn't that be 285 instead of 280?
    Other than that it's nice to see the comparison to other nVidia cards and the 4870X2. It just helps to keep in mind where to rank this one.
    Another nice article. Well done. :thumb:
  5. Matticus
    Matticus ...
    23 Feb 2008
    What?
    Why would you possibly want to leave out a card that is cheaper and better? I thought reviews were about comparisons.
    One thing I would say about watercooling the ati would be the warranty. I know some vendors support changing the cooler as long as you don't cause any damage doing it, but I am sure this was usually nvidia vendors. So while it may be cheaper, if something goes wrong and they cotton on to your watercooling you may end up spending a LOT more.
  6. ry@n
    ry@n Minimodder
    31 Aug 2005
    Great write up, I dont see that as a bad price at all. £100 extra is reasonable as the block alone would be about £60-70 so it means you don't have the hassle of fitting the block and you get to keep your warrenty.
    EDIT: I also had the same trouble with the G1/4 ports being too close together on my Heatkiller CPU block, Im also using 45degree TFC fittings to fix that.
  7. kenco_uk
    28 Nov 2003
    A bit off-topic, but is there a review (to be done by bindi, natch) planned for the MSI X58M motherboard?
  8. Teq
    Teq What's a Dremel?
    11 Aug 2008
    It would have been interesting to do a price/performance/installation comparison with other watercooled solutions, maybe grab a couple of cheap 285's, a full cover EK block and a nice little MCW60, for those of us with existing watercooled graphics hardware I think this might have been more meaningful then.
  9. perplekks45
    9 May 2004
    I think Bindi will kill you for asking for that. :D
    They tend not to have the time to do all they want, let alone all the stuff that would be considered "fun".
  10. [USRF]Obiwan
    9 Apr 2003
    Hmmm sorry, did not look at the perspective of price, leave that out and you would probably have come to the same conclusion as I did :)
  11. Combatus
    16 Feb 2009
    Nope, did mean the GTX 280 - was speaking reference to the RAM that was on the top side of the 280's PCB (some was GPU side, the rest was on the top side and it would get very hot if you didn't use heatsinks when watercooling the card). On the GTX 285 it's all core side so if you have a full cover water-block, all the RAM is water-cooled.
  12. perplekks45
    9 May 2004
    Apologies for not reading/understanding properly.
    In the middle of learning for my final exam for BSc CS. God, how I HATE theoretical CS! :grr:
    Oh, and I blame it on Cheaps of course.
  13. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Nice card but as I said about the other MSI card, far too expensive in the current market. Given you can now get two GTX275 for less than this single card it puts into perspective just how expensive it is...
    The water block does look nice though and seems to cool very well indeed.
  14. Combatus
    16 Feb 2009
    No worries, good luck and enjoy your long holiday after your final exam!:rock:
  15. perplekks45
    9 May 2004
    Long holiday? I wish!
    I studied in Germany so I'm 25 by now [yes, we take our time :p] and I really want to work after living in Bath for the last 10 months without proper job thanks to the recession. Well, I already applied for a couple of jobs at the UN here in Vienna, fingers crossed. :)
    Cheers anyway. :thumb:
  16. BrightCandle
    BrightCandle What's a Dremel?
    30 Apr 2009
    The temperature seen here is a little on the high side in comparison to what most people actually see on a real watercooled system. The reason is the rather poor radiator space in comparison to what you really need for such a hot part. A quiet system would use 1200rpm fans, then the rule of thumb is that a single 120mm radiator can cool the water to 10C with about 100 Watts of load (90-115 depending on the radiator used).
    The GTX 285 is a 185W part, which means really it needs 240mm of radiator to cool it with a quiet fan, and that would halve the delta temperature seen in this review and be more inline with what you would normally get.
    Of course a water cooled 4870X2 is great (what I have) but we could do with some prebuilts or companies that have warranties that cover watercooled cards because at the moment if it breaks you are buying a new card (or committing fraud by sending it for RMA).
  17. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    What? You're confusing my stoooopid American mind.
  18. Combatus
    16 Feb 2009
    We do have a very powerful fan on the radiator - much more powerful than would normally be used so this will compensate as will the fact the lab has some fairly potent air conditioning. The rad itself was barely getting warm so we don't have any doubts that it was in any way over loaded. Agreed though, for a quiet system, a double 120mm rad would be needed.
    delta T is the difference between the ambient air temperature and the temperature reported by the hardware (in this case the difference between the ambient air temperature and the temperature reported in GPU-Z).
    If the temperature of the room is hotter when we test one graphics card, then cooler a week later when we test another, clearly the card tested on the cooler day will have an easier ride and the test is also unfair. A way to get around this is to use delta T - in theory if you test the same graphics card in two seperate rooms each with a different ambient temperature, you'll end up with the same delta T. At extreme temperature ranges this might not hold true, but our lab only varies between about 22 and 27 degrees which isn't an issue.
  19. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    I think they mean that the temp reduced to 19C over ambient then in brackets is the stock cooler performance which would be 56C over ambient
  20. Elton
    23 Jan 2009
    The first thing I thought:
    Yuck, red PCB.
Tags: Add Tags
