Hardware MSI Master Overclocking Arena 2010
Discussion in 'Article Discussion' started by Sifter3000, 29 Jun 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Glix
    Glix Left Thumb Stick in the mud.
    11 May 2010
    Whoops I made the mistake of checking out the picture of Princess Leia.
    Sorry Pc hardware, I was unfaithful, but this has only made me stronger and never again will I make that mistake.
    *hugs Pc*
  3. Glix
    11 May 2010
    Oh and another note:
    WE BEAT GERMANY!!!
    Lol couldn't help myself.
  4. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    is it just me or does anyone else think these Global electronics giants are a bit tight with prizes and prize money?
  5. John_T
    John_T Minimodder
    3 Aug 2009
    Oh my God: The bloke on page 2, bottom left hand picture - they way he's pouring out the LN2 - he's just ASKING to lose his hand!
    I'm not some health and safety freak, but come on, show the stuff the respect it deserves!
  6. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Ive seen heston Blumenthal (the chef) flick it like water with his bare hands so as long as your quick its not that dangerous.
  7. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    I'm not at alll a pro of exteme overclocking buta question came trought my mind:why instead of pot don't they use tubes so the LN2 is directly on the CPU?
  8. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Because as soon as you take the LN2 out of its storage container it starts to evaporate. So, a) its not pumpable and b) you need a vent for the nitrogen (now in its gaseous state) to escape.
  9. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Poor old england, I'm sure the same couple of problems happen at each event :(
  10. Redsnake77
    Redsnake77 Useless Idiot
    7 Jun 2009
    Why were our guys using the wrong bios? Was the one they were using not sanctioned? Or did it just not allow the performance levels needed to be competitive?
  11. Combatus
    16 Feb 2009
    There was a bit of confusion over BIOS versions. Normally moderators come round and check but this didn't happen apparently so they'd already done a few rounds in Super PI before the found out!
  12. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    I've never used the stuff but I think it evaporates too quick to freeze your hand, you would have too dip your hand into it.
  13. Redsnake77
    7 Jun 2009
    OK. But MSI provided the motherboards, CPUs, GPUs, PSUs, and HDDs, so why weren't all the boards loaded with the same bios before the competition started? What about OS configuration, and display drivers? Isn't everyone given the same basic setup? Is the team's ability to find the right bios, and drivers and install them correctly something they're judged on?:eyebrow:
  14. matt...
    matt... Slacker
    18 Nov 2009
    having used LN2 everyday for about 7 years I can say it burns if you leave your hand in ti for too long - but you can flick it or throw it at someones jeans quite safely! ...I've been stuck to the spot for fear of shattering my frozen trousers a number of times :)
  15. Combatus
    16 Feb 2009
    All the hardware is retail boxed so it stands as good a chance of arriving in good order but I guess it's easier and quicker to get each team to flash to the correct BIOS than one person doing this 15-20 times. But yes, it's unfortunate that this wasn't picked up on...
  16. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Are those capacitors normally like that? :confused:
  17. EvoCarlos
    EvoCarlos What's a Dremel?
    29 Jun 2010
    Fantastic pics and what a great event and follow up by bit tech thanks :)
  18. (FIH) The Don
    (FIH) The Don What's a Dremel?
    27 Jun 2010
    It's modded?
  19. Altron
    Altron Minimodder
    12 Dec 2002
    It's called the Leidenfrost effect. What happens is that part of the LN2 evaporates into N2 gas as soon as it touches, so there is a always layer of gas between the liquid and your hand, so it won't freeze you unless you really try to.
    More info:
    http://en.wikipedia.org/wiki/Leidenfrost_effect
  20. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I think he meant sealing an open ended tube to the CPUs integrated heatsink and pouring directly that way, so like a pot with out a bottom.
Tags: Add Tags
