News MSI MPG Quietude 100S silent gaming PC case launched
Discussion in 'Article Discussion' started by bit-tech, 22 Jul 2021.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. David
    7 Apr 2009
    MSI chassis - does the side panel fall off when you update the motherboard BIOS?
    The_Crapman, monty-pup and Arboreal like this.
  3. andrew8200m
    andrew8200m Modder
    4 May 2009
    All these companies that used to sell GPUs, motherboards and on occasion laptops now seem to sell headsets, mice, keyboards, pads, controllers, mics, mini PCs, cases, PSUs...
    Absolute desperation.
    monty-pup likes this.
  4. Cheapskate
    13 May 2007
    The preview icon on the front page looked like it was a domino-shaped tower. Seeing it's just another box was really disappointing.
  5. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    can't hear it coming? bloody will with that K360 in it :hehe:
    Also only has 1 fan installed in the rear as stock. gonna make for one toasty review.
  6. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Meh, if I wanted a "silent" case I would choose the Phankteks P600S over sdomething like this. 3 included 140mm fans as standard instead of 1 (seriously, a single case fan?!), massive expandability and the option to switch it into a airflow setup by simply removing the front and top inserts.
    It's bigger than the MSI case (4cm in length and height and 1cm in width) and likely more expensive (can be had for £129 on Amazon) but the tradeoffs are worth it.
    Alternatively go for one of the plethora of other cases available and run low noise fans for the same result (what I basically do with the Lancool II combined with Noctua fans).
Tags: Add Tags
