Hardware MSI N480GTX Lightning Preview
Discussion in 'Article Discussion' started by CardJoe, 17 Sep 2010.
  1. Guest-16
    Guest-16 Guest
    I got it direct from MSI.
  2. garrett_wu
    garrett_wu New Member
    19 Sep 2010
    If author looks closer on PWM chip and Driver IC spec, he will see the PWM is up6225 which is 12 Phase PWM chip, and advanced Driver IC is specially designed for pushing 2 phase with 1 chip. N480GTX Lightning GPU is 12 phase with no doubt. MSI will never use parallel connection power design on Lightning, and there is NO WAY to hit 1400MHz+ under extreme OC if MSI use parallel connection, MOSFET will simply blow up because of unbalanced loading.
  3. Guest-16
    Guest-16 Guest
    Hi Garret,
    Click for large
    These six told me a different story on the back of the PCB, although if I'm wrong feel free to email or phone me and explain, then ill update the article. :thumb:
  4. TWeaK
    TWeaK Member
    28 Jan 2010
    I don't think the heatsink mount is a problem tbh. It looks to me like it's mounted to the backplate, which in turn has mounts spread all over the PCB. Looks like the load would be spread quite evenly.
    Now, when are the benchies coming Bindi? :D
  5. Guest-16
    Guest-16 Guest
    It's not mounted to the backplate I'm afraid, they are just holes.
  6. garrett_wu
    19 Sep 2010
    The drive is up6282 (http://www.upi-semi.com/Product/ProductList.aspx?ArchID=86) , it's dual phase mosfet driver WITHOUT phase extension function, so you can think it's two traditional single phase MOSFETs packing into single chip. There are too many components on power design of lightning, using more expensive dual phase drive ic can reduce space.
  7. AnonymousBasterd
    AnonymousBasterd New Member
    19 Sep 2010
    I Like the Idea of GTX 480 having like ASUS's Ares & Mars but I'm Worried about the (ONLY) 4 Screws Supporting the Whole Huge Chunk of Heatsink Scare's me also there's No Option for Power Efficiency when Overclocking is Undesired, If Only they'd Fix the 4 Screws Support along with the Optional Power Efficiency, Everything will be Perfect!
  8. Krayzie_B.o.n.e.
    Krayzie_B.o.n.e. New Member
    2 Aug 2009
    Wow another article about a Gtx 480. Everytime I read a Gtx 480 article I get a nice tan and a high electricity bill.
    The Gtx 480 is a monster card but in today's world you gotta produce monster results without all the heat, noise, and nuclear reactor in your basement to power the thing.
    GTx 460 sli is the way to go!
  9. Guest-16
    Guest-16 Guest
    Thanks! :clap: Unfortunately that letting on those tiny ICs is too small for me to see.
    I will amend the article.
  10. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    Unfortunately the nvidia or ati drivers dont give anyone with any common sense the warrant to buy these over-engineered products.
    If this cost so much to make, why dont you plough that into your driver division? i.e. custom drivers = another competitive edge over other companies. i.e. msi vs asus for the 5870 etc.
    This will probably be just as good as a standard 480gtx or a 5870. Therefore not worth the budget. Unless your a folding at home hoarder. This wont (shouldnt) appeal.
  11. Guest-16
    Guest-16 Guest
    Partners never make drivers for graphics cards. Asus tried it once with the Mars afaik and it was terrible. EVGA is the only company that puts the time into SLI updates, but no one has access to the core of the drivers.
  12. Universal_Lord
    Universal_Lord New Member
    25 Aug 2010
    My friend just gave a link that contains a review of this VGA card:
    This card is really much faster than the standard GTX480!:thumb: But the price is also above the standard GTX480.:D
  13. memeroot
    memeroot aged and experianced
    31 Oct 2009
    waiting on the 485... 1 month to go?
Tags: Add Tags
