Hardware MSI NGTX275 Lightning Review
Discussion in 'Article Discussion' started by Guest-16, 31 Aug 2009.
  1. Ta10n
    Ta10n What's a Dremel?
    15 Mar 2006
    Which is all well and good, but the aircraft on the box art is in fact an F-22 Raptor (the YF-22 prototype to be specific) , which is quite fast and extremely agile. Sorry for being today's aircraft nazi :geek:
  2. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Does that meant this graphics card will also crash if it passes over the International Date Line? :)
  3. Ta10n
    15 Mar 2006
    No, but if it crosses at more than 87 mph then it will go back in time..... and destroy ATI :jawdrop:
  4. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Sorry, there's still no thing as solid state chokes. It's still marketing BS.
    There are a number of measures that can prevent Magnetostriction from causing inductors in switch-mode power supplies from producing audible noise, and it's possible (or probable) that they've implemented one (or more) of those. However, promulgating faux electrical terminology only serves to confuse people tho know what they're dealing with, and misinform people who don't.
    Sorry for being such a pedant, but this sort of thing bothers me a lot.
  5. Guest-16
    Guest-16 Guest
    Instead of there being a little bar of iron/ferrite on the inside the whole thing is iron/ferrite coating the coils within. It was just hard to describe :(
  6. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    i wish they start to do something on the idle power state of video cards. Why do they have so much idle power consumption. for normal desktop operations it should not use more then 30 to 50 watts. My guess is that 75% of the time pc's are running in desktop mode.
  7. Combatus
    16 Feb 2009
    TBH we were going by the name! Also when we cross checked the image against those of the F-22 and F-35, we noticed a few things that pointed it in the direction of the F-35 - the front undercarriage has one fork on the box while the F-22 has two (the F-35 has one as well). Also the rear undercarriage has doors mounted mostly in the wing on the F-22 while they are mounted mainly on the fuselage on the box and on the F-35.
    However as you’ve correctly pointed out, the YF-22 prototype is the one were after! Doh! They do look incredibly similar head on though. Consider our hands slapped!
  8. Combatus
    16 Feb 2009
    Don't forget the power levels we state are of the system as a whole, not just of the card?
  9. general22
    general22 What's a Dremel?
    26 Dec 2008
    But if you make a demo of real world gameplay like joining a tf2 server with a full 24 players for about 30 mins then shouldn't that be a good indicator of performance. Also to keep the performance consistent theres some trick that frag video makers use to keep the game at a previous version so they can playback their old demo recordings.
    But I realise that's a bit annoying just to include one game in a benchmark.
  10. Guest-16
    Guest-16 Guest
    No because it's just a recording - there's no computation for realtime interaction. It's worse for Left4Dead. Plus, Valve updates its engine regularly which causes timedemos to generate an incompatibility error.
    You can after some messing about keep the game version, but it's a ton of hassle and just as non-valuable to current players on the latest engine etc.
    Not to mention that the Source engine is about as hardcore as a kitten with a toothpick.
  11. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Hmm, Ultimate Knight Windom XP!!!
    Sorry, just joking. Got hooked recently on the game, though.
    Hmm, ARMA2 should be OK, but I hate the asscap DRM used.
  12. aussiebear
    aussiebear What's a Dremel?
    13 Nov 2008
    Have you folks (or authors of the article) noticed something? Hint: Look at the Folding@Home performance of this review and the last video card review...
    => http://www.bit-tech.net/hardware/graphics/2009/08/31/msi-ngtx275-lightning-review/9
    and
    => http://www.bit-tech.net/hardware/2009/08/26/galaxy-geforce-gts-250-1gb-review/7
    ...Heck, look at the GTX260 version of MSI's Lightning line! (Back in July)
    => http://www.bit-tech.net/hardware/graphics/2009/07/06/msi-n260gtx-lightning-review/13
    ...Doubling the memory of a mainstream/performance Nvidia video card does improve F@H performance! So it isn't a one off anomaly!
    This brings the question: Is it better to have more RAM on the video card OR a card with dual GPUs? (Total F@H output comparison?)
    You folks gotta try and explore this in a "GPU Folding@Home Performance" article! ;)
  13. rickysio
    6 Jun 2009
    Double GPU is always better than Double RAM.
Tags: Add Tags
