News MSI no longer supports 125W CPUs in the K9A2 CF
Discussion in 'Article Discussion' started by Tim S, 28 Jan 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Guest-23315
    Guest-23315 Guest
    One guy on the forums had an issue aswell.
  3. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    how to name a revision? K9A2 CF rev2....... i think people wont get that wrong.....
  4. naokaji
    naokaji whatever
    8 Dec 2006
    thats one of the reasons why retailers would be a nice thing to have... you could simply look at it to see what rev it is.
  5. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    After having bought a few MSI products I have to say that I was very happy with some of them but other times their support was atrocious - they promised features (even advertised them on the box) but never delivered. They promised a fix in a future driver release then revised the product (/ created a new, similar, one) and abandoned all work on the version I had. It would takes a lot to convince me to buy MSI again - stories like this make that even more unlikely.
  6. seveneleven
    seveneleven New Member
    26 Dec 2007
    At the same time there's a banner on the right side of this site praising the K9A2 CFs support for Phenoms - oh the irony...
  7. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    the thing is that not all e-tailors tell you the revision of the board, how are you meant to know then?
  8. Tim S
    Tim S OG
    8 Nov 2001
    It'll support the 9500 and 9600, as they're 95W parts. :)
  9. jim48509
    jim48509 New Member
    28 Jan 2008
    Quote: In light of all this response and evidence, our current recommendation is that you look elsewhere for an AMD 790X motherboard, at least until MSI revisits this board.
    3 days too late, I bought this board with the AMD 64 X2 6400 which I have running at 2.8 ghz to keep the power lower. So far so good.
    The Canadian MSI web site still lists the K9A2 CF as supporting the 125W parts, I wonder how the resellers who are building and selling systems using this board and the 125W parts are feeling?
  10. Guest-16
    Guest-16 Guest
    Sorry we didn't post this earlier, Jim! We had to wait for MSI to reply to our questions.
    I hope it keeps working for you!
    Unfortunately the local MSI websites are updated locally so sometimes updates don't get through quick enough.
  11. talladega
    talladega I'm Squidward
    18 Aug 2007
    is there any such problems known to the MSI K9A2 Platinum that uses the 790FX? Thats what im looking at buying.
  12. DXR_13KE
    14 Sep 2005
    just slap a REV2 at the end of the name......
  13. jim48509
    jim48509 New Member
    28 Jan 2008
    No worries, at least I found out before I ran it at 3.2 ghz. I think I will fit a smoke detector inside the pc case :D
    I am going to make an assumption,
    msi did say that the board would support the 125w parts so the vrm's should supply the power requirements therefore the issue would be heat related as there are no heatsinks on the vrm's ?
    If the vrm's can be kept coolish would it then run the 125w parts or is the answer not to be such a tight ass and get a good board ( non msi )
    Was the AMD 64 x2 6000 you used in the original article the 125w part?
  14. Guest-16
    Guest-16 Guest
    Yep, 125W part.
    As for the platinum - check the MSI site but it should work just fine.
  15. Shielder
    Shielder Live long & prosper!
    26 Jul 2007
    Just like they are still advertising Evesham Technology here too...
    Andy
  16. Tim S
    Tim S OG
    8 Nov 2001
    That story is known to be false - we spoke to Evesham's MD the day it was published. I have nothing to do with advertising on bit-tech, but I can tell you that we wouldn't be running the ads if the company wasn't paying its bills.
  17. Shielder
    26 Jul 2007
    Oh. Sorry. Just shows, you can't trust everything you read on the web... :)
  18. MRZ258
    MRZ258 New Member
    31 Jan 2008
    hello.. i'm newbie here. and accidentally register just because of this K9A2-CF mobo. I bought this MOBO on 18 Jan 2008 right after i read bit-tech review.
    Luckily i also navigate trough the MSI GLOBAL website before make a final decision.
    It is sad to say that this MOBO cant run any 125W AMD X2 CPU.. but dont worry may friend, if u need 3.+ Ghz CPU to runnign with it,
    AMD X2 5000+ Black Edition is a right choice... i read some review in the net about this cpu. yu can change the multiplier from 13 to 16 make you
    reach 3.2Ghz (default is 2.6Ghz).. correct me if i'm wrong.
  19. Bladestorm
    Bladestorm New Member
    14 Dec 2005
    Increasing the speed a CPU is running at, also increases its power consumption.
  20. MRZ258
    MRZ258 New Member
    31 Jan 2008
Tags: Add Tags
