Reviews MSI Optix MPG27CQ Review
Discussion in 'Article Discussion' started by bit-tech, 17 May 2018.
  1. bit-tech
    bit-tech Supreme Overlord Staff Administrator
    12 Mar 2001
    Read more
  2. loftie
    loftie Modder
    14 Feb 2009
    Wait, no LFC? You sure? Hardware unboxed reviewed it saying it did have. Would be odd not to have it the range is big enough to be capable of it, though I don't really know how LFC 'works' I've always assumed it was the GPU frame doubling. :confused:
  3. Hustler
    Hustler Minimodder
    8 Aug 2005
    They keep pumping out these Freesync monitors for use with a company's GPU's that are a waste of time and priced so ridiculously high compared to their Nvidia equivalents that hardly anyone will be able to take advantage of the feature.
    TheMadDutchDude likes this.
  4. Dogbert666
    Dogbert666 *Fewer Staff Administrator
    17 Jan 2010
    Yeah the range would suggest it does. I will check with MSI and see, but originally we were told they couldn't confirm it.
    Update 18/05/2018: We had a miscommunication with MSI, and it has now been in touch to confirm that LFC is indeed supported. It is also looking to get an entry for this monitor placed into AMD's otherwise comprehensive list of FreeSync monitors.
    This update has also been placed in page one and seven of the article. Apologies again for the confusion here.
  5. loftie
    loftie Modder
    14 Feb 2009
    No confusion :)
    Are these using the same panels as the samsung equivalents are?
  6. ModSquid
    ModSquid Minimodder
    16 Apr 2011
    "You also won’t find comparable G-Sync screens for anywhere near this price" - although not curved and sans RGB, the Acer Predator is going for 500 on Amazon. Does that not count?
Tags: Add Tags
