Hardware MSI P35 Diamond
Discussion in 'Article Discussion' started by Tim S, 24 Sep 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
    http://www.bit-tech.net/hardware/2007/09/24/msi_p35_diamond/1
    MSI's P35 Diamond features the same CircuPipe cooling system as the P35 Platinum, but comes with a few added features like a PCI-Express X-Fi, a SkyTel Skype card and DDR3 memory. Do these ingredients create a better board than the Platinum?
    :geek:
  2. widmod
    widmod Member
    9 Oct 2006
    you can't use this motherboard without a graphic card?
    some special fans in the circuit heatpipes would have been nice
    quite much PCI slots are used if you trow everything in which is in the box :wallbash:
  3. DivineSin
    DivineSin New Member
    23 Apr 2004
    Is it just me or are most of the higher class motherboards coming short of expectations, and not worth it when you consider price?
  4. ssj12
    ssj12 Member
    12 Sep 2007
    this is supposed to be a high class motherboard? im not impressed.
  5. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    wholly crap crossfire 1600*1200 is an incredible boost.
    I think they consentrated on the X38 instead
  6. Tim S
    Tim S OG
    8 Nov 2001
    A lot of them are, yes... you just can't put a few flashing lights on the board and increase the price by 50 percent.
    I think the problem for most high-end boards at the moment is making the choice between DDR2 and DDR3 - if you head into the realms of DDR3, you're going to be classed as expensive because that's exactly what DDR3 is. There's no way to get around that. :)
  7. Woodstock
    10 Sep 2006
    correct me if im wrong (i must be) but wouldnt 16 * 4 (total of 20) use more pci express lanes then 8 *8 (total of 16)
  8. Tim S
    Tim S OG
    8 Nov 2001
    That's right, but P35 has a limitation where you cannot split the first 16 lanes into two eights. You have to run at full x16 bandwidth in the primary slot, unless you use a lane splitter (that's what Asus did on the Blitz). :)
  9. Guest-16
    Guest-16 Guest
    16 from the northbridge, 6 from southbridge - 4 are used to the second slot, one is for the gigabit ethernet and one is for the marvell ide chipset.
    So Crossfire data has to navigate and fill the DMI between NB and SB, unlike X38 which is all connected to the NB so the whole thing should be lower latency.
  10. Woodstock
    10 Sep 2006
    edit: ingnore
  11. Woodstock
    10 Sep 2006
    edit: ingnore
  12. Woodstock
    10 Sep 2006
    i see said the blind man to the deaf monkey
    which costs money of cause
Tags: Add Tags
