News MSI P965 Platinum features Crossfire support!
Discussion in 'Article Discussion' started by Da Dego, 19 Sep 2006.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Sweeeeeet. :)
  3. suicidal-kid
    suicidal-kid What's a Dremel?
    10 Mar 2006
    Damn. Just when I had my next systems mobo picked out, they throw this one in. They are not making this easy for me.
  4. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    hmm it is tempting but dont you need a master card if it hasnt got an ati chipset? they are pretty hard to get now
  5. TonyM16
    TonyM16 What's a Dremel?
    20 Sep 2006
    Hey? What do you mean? Even ATI chipsets need master cards for crossfire. Masters are easily available at the same place you find ATI cards. It is true however that only the X1900 master card is being sold at the moment. For all other ATI gpus' in the X1K series aprt from the old flagship X1800XT you can have crssofire with two identical gpu's without the need of a master card. This will work on Intel and ATI chipsets if they are crossfire ready regardless of who made it.
  6. TonyM16
    20 Sep 2006
    In the news article it says this mobo has two x16 pci express slots as it was built for crossfire from the ground up, is this really true? I thought all Intel chipsets only have two x8 pci express lanes for multi gpu much like the old Nforce boards . I know that it will have one x16 pciex for single gpu, but for dual gpu it usually gets split between the two like with the X975 and older nforce boards.
    So are we really going to get x16 lanes for each gpu? If this is true this will be the most desirable mobo .
    As the P965 is more stable, overclcokable ,reliable and better performing than x975 boards ( no bs, it is defintley better). The only reason to buy the x975 was for the the multi gpu setup and higher fsb. The fsb is now the same as x975 and it now has crossfire (hopefully dual x16). Can't wait.
    Please confirm for me however if it really is dual x16 pci express, as I have a feeling that it isn't, as it would require an extra chip or much extra transistors on the intel chipset.
  7. alastor
    alastor Minimodder
    6 Sep 2004
    According to VR-Zone, ATI is about to launch Crossfire compatability on all 965 motherboards:
  8. klasika
    klasika What's a Dremel?
    2 Aug 2007
    Guys I have one probobly stupid question but...
    Can someone from you answer to me , where is the chip for bios on this board?
    is it integred or...I would like to see the pic or something....
    Thank you :)
Tags: Add Tags
