Overclocking MSI Twin Frozr III 560Ti Hawk
Discussion in 'Hardware' started by AoE, 30 Dec 2011.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    I am new to overclocking GPU's, basically need to know what the safest ratio's are for overclocking the card. My core clock and shader do not seem to increase/decrease off one another so I need to adjust each one manually, same go's for the memory clock. I.e for every 5mhz increase in core, how much should shader and memory clocks change?
    Current core: 955Mhz, +5mhz from stock
  2. Deders
    Deders Modder
    14 Nov 2010
    Generally for fermi, the shader cores are twice the GPU speed.
  3. AoE
    4 Oct 2011
    Ok so 2:1 ratio, if I increase core by 10mhz, I should increase shader clock by 20Mhz?
  4. Deders
    Deders Modder
    14 Nov 2010
    That's what I would do for best sync. Although you may get even faster results in some cases with one higher than the other. Not tried it on mine so can't be sure.
  5. AoE
    4 Oct 2011
    I will try that 2:1 ratio and regarding memory clock, should this be increased if so whats a safe limit
  6. AoE
    4 Oct 2011
    what does the memory clock do and should it be increased along with core and shader?
  7. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Memory clock basically means how much data can be passed to and from the memory. Faster the clock, more bandwidth there is. It doesn't make as much difference to performance though as shaders and core.
  8. AoE
    4 Oct 2011
    What is a decent increment for the memory clock?
