Hardware MSI X58 Pro
Discussion in 'Article Discussion' started by Tim S, 12 Mar 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Tyrmot
    Tyrmot Minimodder
    12 Mar 2008
    yuk. How much money can that crappy PCB really save?? Still, a fair budget choice for now I suppose
  3. dec
    dec [blank space]
    10 Jan 2009
    ive always wondered where people came up with such ridiculous colors. now i know that there was only one color left in the office that everybody brings with them in the morning. that nasty coffee color
  4. Matticus
    Matticus ...
    23 Feb 2008
    Wow, I am more concerned about the lavender sata ports than the brown pcb tbh.
    I cannot understand why they thought brown pcb and lavender ports would be a viable choice for a £160 motherboard. If this was nice looking then it would really get people into i7s, but if this is what you can expect from the low end of i7 boards then there is no point for most to move away from their c2s.
  5. Guest-16
    Guest-16 Guest
    Poor Lavender at MSI! You are so mean to her!! She's really a very nice lady I'll have you!
  6. timmehtimmeh
    timmehtimmeh Minimodder
    2 Jan 2005
    who cares what colour it is. Its a computer. If you want to spend the extra on having somthing nice to look at, go spend it.
  7. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    absolutely. what i see here is a board that is competing directly with the likes of 790FX and all those hoping to get a free core out of a Phenom II X3 and saving money in the long run. This just made that choice a bit more difficult as a cheap (ish) corei7 build.
    still, £400 on a mobo and "entry level" CPU is still mad money, remembering that you still need to cough up at least another £100 for some decent DDR3
    i say bravo, not everyone cares what colour their PCB is as long as the end result works and pwns their 3DMark scores.
  8. Claave
    Claave You Rebel scum
    29 Nov 2008
    We do have another cheap)ish) Core i7 board in the pipeline which looks a bit better - just have to finish the write-up, but we're aiming for early next week. Anyone thinking that you have to settle for poo-brown PCBs on cheap Core i7 boards should be pleasantly surprised...
  9. lemel
    lemel bit-tech.net n00b.
    5 Apr 2008
    Why is everyone so brownist, who could live without coffee and chocolate?
  10. TheStick
    TheStick What's a Dremel?
    20 Feb 2009
    Apparently if you use the bios for the X58 Pro SLI with the X58 Pro the X58 Pro will gain the ability to run SLI. Meaning they are probably identical in terms of hardware with the bios enabling SLI.
  11. Guest-16
    Guest-16 Guest
    Yea we just found that out this morning, after we posted the review :(
    We were going to do something about an update..
  12. TheStick
    20 Feb 2009
    Oh, right :)
  13. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    guys lol its just colors, but I guess I concern myself more on function then form ~_~
    Just get yourself a CM V10, and a couple of Bricks (GTX 295) and you wont have to worry about looking at the motherboard lol as it will be hidden behind that hardware =p
  14. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    I just wanted to let you know that some of the clickable pics on page 2 don't work :)
  15. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
    So its going to be a fashion parade that determines the outcome of the review :D
  16. Guest-16
    Guest-16 Guest
    Fixed!
  17. ¦Cold¦
    ¦Cold¦ What's a Dremel?
    24 Feb 2009
    I think the point is it probably would have cost them almost nothing to add a different colour to the PCB during manufacturing, but they left it brown to intentionally put people off by thinking it's a budget model so they'd buy their higher end products.
    Which is false logic anyway, seeing as I'd rather have the Gigabyte UD4P or P6T Deluxe.
  18. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Yeah, but think of it this way: if MSI was the only purveyor of X58 boards, that might work well. But they aren't, and not every board maker will make their budget boards look hideous. If I bought one, I'd surely create air ducts to cover some of that uglyness.
  19. i7lova
    i7lova What's a Dremel?
    8 Apr 2009
    How would one go about doing this? I have the MSI x58 Pro board and was more interested in going SLI than Crossfire!
  20. brokenmonkey
    brokenmonkey What's a Dremel?
    19 May 2009
    I have this in a red case with red LEDs and you can't even tell that the PCB is brown.
Tags: Add Tags
