Hardware MSI Z170A Gaming Pro Carbon Review
Discussion in 'Article Discussion' started by Combatus, 1 Feb 2016.
  1. Combatus
    16 Feb 2009
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    Excellent review and it looks a cracking Motherboard, decent price & aesthetics..shock horror!!
    Are you looking and learning Gigabyte...
    A neutral coloured board like this would make a great foundation for colour coded components, especially in something like the gun metal grey Phanteks Evolv case.
  3. Combatus
    16 Feb 2009
    Thanks Hustler! Admittedly the RGB lighting in some of Asus' resent efforts has been better but then they do cost more. So long as the PCB and detailing is neutral as you say, that's the main thing though.
  4. Dan848
    Dan848 What's a Dremel?
    25 Sep 2009
    Subdued board colors seem to be the rule these days with mostly black or very dark grey. That and "pretty" lighting are worthless to me. I do not have my case open so I can look at the motherboard.
    I consider longevity, hardware support or features, and overclocking potential, in that order, most important. As to overall performance, most Z170A motherboards are basically tied at the moment. When I build a computer I want it to last 5 or 6 years or more with the only thing needed replaced are a worn out power supply for stability and longevity and faster video card replacement to keep up with higher demanding games.
    Thank you for the review.
  5. Vault-Tec
    30 Aug 2015
    Sorry if I missed it but what exactly controls the LEDS? is there an app MSI provide? I can't see any pics of it.
    Edit. NVM found it here.
Tags: Add Tags
