Motherboards MSI Z68A-GD80..Asus P8Z68 Deluxe or Gigabyte GA-Z68XP
Discussion in 'Hardware' started by numanoid, 30 Jul 2011.
  1. numanoid
    numanoid Minimodder
    26 Apr 2009
    Which one guys...i got a few bob heading my way this week so going to buy me one of these boards...price dont matter i just need to know which of these boards is the better one...Ill be using a 2600k cpu and a corsair H80 and 8gb of corsair vengeance ram.
    thanks guys
  2. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Why are you going for Z68 over P67? Just curious
  3. numanoid
    numanoid Minimodder
    26 Apr 2009
    well the z68 has the onboard graphics so while im waiting to buy a decent graphic card i can be installing windows and surfing the net
    thanks
  4. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    I'd go for the MSI personally from those 3 (rather keen on the maximus IV gene, though).
  5. numanoid
    numanoid Minimodder
    26 Apr 2009
    Any reason for msi matey...i have always used msi when i was using amd cpu's, and used an asus p8p67 evo when i got my sandybridge cpu..(but had to sell to get my season ticket)...so buying my stuff back now and want a realy decent motherboard
    thanks
    take care
  6. faugusztin
    11 Aug 2008
    1) P8Z68 Deluxe doesn't have graphics outputs. Only the Pro and the P8Z68 without a name.
    2) GA-Z68XP - which model ? This is like saying i want a Asus Z68 board :).
  7. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Good point, there are a couple Z68XP models
  8. numanoid
    numanoid Minimodder
    26 Apr 2009
    I didnt know that about the delux mate, i thought z68 replaced p67 so that you can use the graphics part of the sandybridge cpu???? the GA-Z68XP-UD3-ISSD was the one i was looking at mate
    thanks
    take care
  9. faugusztin
    11 Aug 2008
    P8Z68 Deluxe is sort of like the Gigabyte Z68X boards - they have Z68 chipset, they have the SSD caching feature, but the rest of the Z68 features are not present or cripled.
    GA-Z68XP-UD3-ISSD - any specific reason ? The embedded 20GB SSD for caching ? Well, the SSD caching feature is pretty stupid and limited, plus this board is overpriced as hell. £203.62 vs £148.42 for P8Z68-V PRO means £55 just for that 20GB SSD ? Get a 40GB Intel 320 Series for £10 more instead, or just get a good 80-120GB SSD and you won't need SSD caching at all.
    Plus Asus has Intel gigabit ethernet controller vs the Realtek on gigabyte.
  10. numanoid
    numanoid Minimodder
    26 Apr 2009
    Well it doesn't have to be the GA-Z68XP-UD3-ISSD.....even the Gigabyte GA-Z68X-UD4 would be fine.....i was thinking towards the msi or the asus then noticed the
    Gigabyte z68's.....so realy not sure what each offer over the other
    thanks matey
  11. faugusztin
    11 Aug 2008
    Again, if Gigabyte then you need one of the XP boars - because the X boards don't have any graphics outputs.
    Z68 boards from the Asus/MSI/Gigabyte come pretty much down to :
    1) Do you want the graphical outputs ? This removes Gigabyte Z68X (without P) boards, Asus P8Z68 Deluxe and ASUS Maximus IV Extreme-Z.
    2) What graphical outputs do you need ? Gigabyte Z68XP and Asus Maximus IV Gene-Z gives you only HDMI, MSI and Asus P8Z68-V & Pro gives you DVI, HDMI and most time VGA too.
    3) Chips used - Ethernet (Intel vs Realtek), eSATA,...
    4) BIOS for Gigabyte vs EFI for Asus and MSI.
    I personally have no issues with my P8Z68-V Pro.
  12. numanoid
    numanoid Minimodder
    26 Apr 2009
    Well i was thinking one with vga output but as i think about it ill be getting a vga card within the next month, so vga output not realy essential but would have given me the option of putting windows onto my drive...but i can wait until i get my vga card....so p68 board could do the job...HDMI and DVI are prefered...but has to be ATX not Micro ATX
    thanks
  13. kenco_uk
    28 Nov 2003
    I'd recommend the Asus P8Z68-V Pro. 8 sata ports, hdmi/dvi/vga out, usb3 bracket. Good reviews, too! The P8Z68V has 6 sata and omits the bracket I think.
  14. numanoid
    numanoid Minimodder
    26 Apr 2009
    Thanks kenco...
    but ive just ordered the MSI Z68A-GD80...as i thought to myself ive had the p8p67 evo (not much difference to the p8z68-v pro you recomended)...so thought time for a change...just wondering now if the msi will take 14900 memory..i can get 12800...is there much difference
    thanks guys for all the help
